Driving without the x brace
Old Mar 21, 2008 | 02:41 PM
Bensons86's Avatar
Bensons86
Default Driving without the x brace
I am doing some work on the overdrive unit of my 4+3. Is it safe to give it a test drive without the x brace. (86 vert). That thing is a real pain in the butt to take on and off and if the overdrive is still leaking, I would just assume not have to mess with that brace if I don't have to. Anyone know?
Old Mar 21, 2008 | 02:57 PM
86PACER's Avatar
86PACER
Nothing will happen. I've been driving without mine for years. After I installed some Hookers and aftermarket exhaust, the x brace would no longer fit because this exhaust was not flush to the underbody like the factory system was. Doing a test drive without it is not going to hurt a thing.
Old Mar 21, 2008 | 03:03 PM
rube1975's Avatar
rube1975
the x brace is mainly to protect the under body so stay away from tall speed bumps and you'll be ok
Old Mar 21, 2008 | 03:27 PM
Strick's Avatar
Strick
I ran into the same problem with my 3" B&B cat back. There was so little clearance between the top mount and the X-frame that it would hit when I hit a good bump. I went back to the factory exhaust with elims. Now the beautiful B&B with an H-pipe all welded together, hangs in my shed, what a waste.
Old Mar 21, 2008 | 03:35 PM
Bensons86's Avatar
Bensons86
I was told a long time ago that the x brace was to keep the body from flexing under the torque in light of it being a convertible and not having the extra support from the roof. The coup doesn't have the x brace.
Im understanding you to say that this isn't correct. ????????
Old Mar 21, 2008 | 04:35 PM
Bad Karma's Avatar
Bad Karma
I wouldn't drive long term with it off. But for a test drive, and if you aren't beating on it you should be okay. But I would put it back on as soon as you have you rissue resolved.
Old Mar 21, 2008 | 05:09 PM
rube1975's Avatar
rube1975
Old Mar 21, 2008 | 07:22 PM
MK 82's Avatar
MK 82
It's there to stiffen the chassis not protect the bottom. The coupe doesn't have one!
Old Mar 21, 2008 | 07:53 PM
86PACER's Avatar
86PACER
Yes, this was put on verts to make up for the lost stiffness of a soft top. That is why coupes don't have it.
Old Mar 22, 2008 | 09:13 PM
shawn 84&92's Avatar
shawn 84&92
Mine has been off of my 92 for over four years, no problems.
Shawn
Old Mar 22, 2008 | 09:27 PM
MK 82's Avatar
MK 82
Shawn
As long as you don't do a little spirited driving on a closed course!
Old Mar 22, 2008 | 09:51 PM
C-4 Now's Avatar
C-4 Now
Only drove once without. Could instantly tell difference in body flex and rattles! I might be a little fussy as I really prefer to also have hardtop on for longer road trips!! Really feel convert with hardtop is tighter than same year/equipment coupe. Have done some back to back driving of cars when new!!
Old Mar 22, 2008 | 10:05 PM
93cruiser's Avatar
93cruiser
The xbrace makes a world of difference on my 93 vert. How difficult is it to install on 94 coupe? With the top off I can not tolerate the lack of stiffness. If you are driving on smooth roads or interstate highways it is hard to notice the difference though.
93cruiser
Old Mar 22, 2008 | 10:33 PM
NASCAR314's Avatar
NASCAR314
here is what you need for a 94 coupe:
http://www.r-dracing.com/CROSS-FRAME.htm
I've removed and replaced my "X"-brace more times than I care to count on my 96 vert., yes, it's a PITA!, but not as bad as that dang "Driveline Support", although I have now gotten that down pretty well also. practice, practice, practice.....
Old Sep 30, 2009 | 05:12 AM
hawkshil's Avatar
hawkshil
Thank you for posting a web site for these, i apparently wasn't googling the right stuff to find it myself.
Old Sep 30, 2009 | 10:10 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
My 92 Vert had an X brace. It did minimal work, I used to call the Vette "The Titanic" I thought it would brake in half while going up on driveways etc.
To Driving without the x brace
