What rear diff do i have?
Old Mar 21, 2008 | 10:43 PM
383tpimachine's Avatar
383tpimachine
Default What rear diff do i have?
I looked at the RPO codes under general info and couldnt figure out what rear I had.
its an 85 and by the RPO post It has to have a G44 or G36 right?
maybe im just being a newb since i dont know codes
can anyone help?
Old Mar 21, 2008 | 10:49 PM
Corvette Chris's Avatar
Corvette Chris
What transmission does your car have?
Old Mar 22, 2008 | 12:03 AM
combustables's Avatar
combustables
If your car has an auto trans it has a dana 36. If it has a manual trans it has a dana 44. The search function is your best friend. At your age, I was WALKING.
Old Mar 22, 2008 | 12:10 AM
wayne lowry's Avatar
wayne lowry
By the center bolt in the top of the rear cover. The D36 has one, the D44 doesn't. D36 = 9 cover bolts. D44 = 8 cover bolts. All autos had the D36. 1985 and up manuals had the D44. RPO "G87" Since these cars are old and some have been modded the best way to see what YOU have is to climb under it and check it out. A Dana 44 swap in an automatic car is not uncommon.
Old Mar 22, 2008 | 12:15 AM
383tpimachine
Its an Automatic
and i looked with the search and everything just didnt understand it
so the Dana 36 was a 2.59 right?
Old Mar 22, 2008 | 12:23 AM
wayne lowry
G44 - 3.07 Rear Axle Ratio
G87 - ring gear 8.50 inch
G92 - Performance Axle Ratio
GHO - 3.54 axle ratio
GM1 - 2.59 Rear Axle Ratio
GM3 - 3.45 Rear Axle Ratio (8.5 in. Ring Gear)
GT7 - 3.33 rear axle ratio
GU2 - 2.73 Rear Axle Ratio
Old Mar 22, 2008 | 10:57 AM
383tpimachine
And now comes my most newb question
The RPO code is the VIN right?
thats what i have been thinking and maybe thats why NONE of those codes appear to me
so is the VIN the RPO?
Old Mar 22, 2008 | 11:06 AM
toptechx6's Avatar
toptechx6
You can answer a lot of your own questions if you take the time to read the Technical Summary at the top of this forum section and the one on RPO codes at the top of the C4 General forum.
Old Mar 22, 2008 | 11:11 AM
Aurora40's Avatar
Aurora40
Open your center console and look under the lid. There is a a label there with the RPO's listed. The VIN doesn't have any RPO's in it.
Old Mar 22, 2008 | 11:23 AM
383tpimachine
OK thanks
but there is a really big problem with the center console
NO STICKERS or anything for that matter
so im guessing only way now is to open up the rear?
Old Mar 22, 2008 | 11:25 AM
Aurora40's Avatar
Aurora40
Or look at the revs when cruising at a given speed.
Old Mar 22, 2008 | 11:26 AM
JackDidley's Avatar
JackDidley
Click for RPO codes.
http://forums.corvetteforum.com/showthread.php?t=956104
Old Mar 22, 2008 | 11:30 AM
383tpimachine
Cant check the RPM yet since engine isnt back in it
With the 2.59 at 70 i should be looking at about 1400-1600 right?
Will stroking the 350 to 383 increase rpm? or will it be the same as stock?
Old Mar 22, 2008 | 12:01 PM
clf93lt1's Avatar
clf93lt1
jack up the rear of the car, turn the rear wheel one full turn and count how mant times the drive shalf turns. if it turns 2 1/2 times its a 2.59 if it turns 3 times it a 3.07.
Old Mar 22, 2008 | 12:10 PM
383tpimachine
ok thats what ill do thanks everyone
Old Mar 22, 2008 | 12:20 PM
Josiah_Kennedy's Avatar
Josiah_Kennedy
1st Gear
If your RPO codes arent under the center console, they are under the lid to the rear storeage compartment!!! No need to go jacking the car up!!!
Old Mar 22, 2008 | 12:31 PM
383tpimachine
OK i found it and its G92
so is there no way to tell??? besides rpm or rotating the wheel?
To What rear diff do i have?
Old Mar 22, 2008 | 12:37 PM
MK 82's Avatar
MK 82
There should be another G code close to the G92 that tells the exact ratio.
Old Mar 22, 2008 | 12:42 PM
383tpimachine
it goes from D36 stright to G92 then a K** code
Old Mar 22, 2008 | 12:53 PM
Demonic85's Avatar
Demonic85
In '85 automatics only came with 2 gear ratios, both of which use a D36. The base ratio is 2.59, and the optional RPO G92 which is a 3.07
