I am reinstalling the engine and was bolting the flywheel back on and noticed movement. Movement from the machined surface and the flywheel with the teeth. I look in the Service Manual and it says slight movement is acceptable.
What do they mean by slight? I have aprox 1.5" of movement. Is this slight? If anyone has any thoughts it would certainly help out.
The cluch already has hot spots which give it "One Strike" for rplacing it, but I need to know if this is "Strike Two"
