alum front lowering bracket help
Old Mar 23, 2008 | 07:45 PM
mbsoak's Avatar
mbsoak
Default alum front lowering bracket help
I"ve searched and searched can" find only one ref to modify Mid America alum front bracket. Have installed wedges ready to finish. only one I found said .80" is this correct, I know this haqs been hashed over and over just want to confirm, Thank you Craig
Old Mar 23, 2008 | 07:52 PM
StealthLT4's Avatar
StealthLT4
All you do is cut off the difference in ride height off the ends of the aluminum piece. If the wedges are 0.5" shorter than the total bumps + aluminum piece was, then you cut off 0.5". It's not really an exact science; just so long as the spring isn't loose in there, you're good.
