Super Ram runner to plenum bolt solution
For those of you who've taken the SR off and on several times know, access to the runner to plenum bolts is a horrible design.
Look at the above test fit pic and I think you will pick up right away one of the modifications the shop made to my plenum, the runner bolts can now be installed from the inside of the plenum.
http://www.cardomain.com/ride/2236613
All shiney bling is off the motor and the supercharged, everything is being reworked in black winkle coat and brushed aluminum. The shop is also making a custom aluminum radiator shroud to replace the plastic piece.
The above picture is too dark, but I'll post some better photos soon.
So far, this is a portion of the winter laundry list, there is still a lot of work to get done before the start of the cruise/race/show season:
...................- BS3 computer upgrade - DONE
...................- battery relocation - DONE
...................- add pulley to increase crank pulley belt contact - DONE
...................- MSD 6AL and MSD Boost controller relocation - DONE
...................- NOS purge relocation - DONE
...................- FMU removal - DONE
...................- upgrade blower surge valve - DONE
...................- correct SR vacuum loss - DONE
...................- B&M Transmission lock-up controller - DONE
...................- Phantom gauges and aluminum dash - DONE
...................- fuel management upgrades - DONE
...................- polish out clear coat paint run on fuel door - DONE
...................- stainless steel braided AC lines - DONE
...................- switch to another cam with greater lobe separation - DONE
...................- Aeromotive fuel pump control unit - DONE
...................- bottom end inspection - DONE
...................- new 8.5 MSD wires for custom looms - DONE
...................- new timing chain - DONE
...................- brushed aluminum valve covers - DONE
...................- Pro-billet MSD distributor - DONE
...................- install ATI fluid dampener - DONE
...................- black wrinkle coat on blower tubes - DONE
...................- convert polished aluminum to brushed aluminum - DONE
...................- modify throttle body - DONE
...................- route dual purge line through side of scoop - IN PROCESS
...................- MSD Blaster coil - IN PROCESS
...................- dyno tuning - IN PROCESS
...................- 48 # injectors - IN PROCESS
...................- drop bars for roll cage, to tie in the rear hoop to the front of the car - MIGHT DO THIS
...................- connect amps to Optima battery - IN PROCESS
...................- hide all wires in engine bay - IN PROCESS
...................- modify fuel rails - IN PROCESS
...................- black wrinkle coat alternator - IN PROCESS
...................- custom wire loom for plug wires - IN PROCESS
...................- custom aluminum radiator shroud - IN PROCESS
...................- new shifter plate, pistol grip **** and boot - IN PROCESS
The old long bolt through the lid trick, or am I missing something? I'm not seeing anything unusual in the plenum jumping out at me, but I always leave the lid on when pulling my plenum. Its been awhile since I've seen the inside. Did you fill the tricky inner holes?
I remember seeing your car a few years ago in Rochester. An impressive ride to be sure.
