Frozen clutch?
Old Mar 25, 2008 | 08:10 AM
Foy00's Avatar
Foy00
2nd Gear
Default Frozen clutch?
Took my 92 LT-1 out today for a ride. While doing about 60 MPH I dropped it out of 5th gear into neutral, letting it cost out until my speed dropped to about 40 MPH. When I went to put it back into gear, the clutch went to the floor way too easy. I let it come back up to normal position but when it did, the clutch petal was hard as a rock!! Had to get a $200 tow back to the shop. My mechanic said that coasting out at that speed for an extended period of time is probably what caused the problem (anyone ever here of that?) but was unsure of what exactly the problem was. I was hoping it was the master or the slave cylindar but he already pulled those and all was well. Anyone have any ideas?!
Thanks for the help
Ray
Old Mar 25, 2008 | 09:13 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
You should be able to coast all day long. Sounds like somethng gave way in the pressure plate. Or as all the commercials say these days, "it's not your fault"!
Old Mar 25, 2008 | 11:54 AM
jhammons01's Avatar
jhammons01
When the pedal went to the floor you pushed the slave cylinder piston outwards then when you pushed it again the piston bottomed out against it's own housing. This is why it is hard as rock.....it's bottomed out.
Don't push it again as it might still be usable. But once you force the piston out, you may damage the Slave.
The mystery here is finding out what let go. Somewhere in there the fork is not contacting anything. The "Throw Out" bearing may have let go, or anything along the lines of the clutch.
You'll have to get a mechanic that is honest. Claiming that coasting too long was the culprit....that would have me pushing my car out of that shop.
And thinking about it just a bit......"Frozen Clutch" terms.....makes me start to think what is broken.....maybe just the slave cylinder rattled loose......
Old Mar 25, 2008 | 12:10 PM
Iroc57's Avatar
Iroc57
I have an auto so the only advice to you is to get to a new shop.
Any "mechanic" that say's that is the cause should not touch your car.
I'm sure that all will work out
Old Mar 25, 2008 | 12:30 PM
sothpaw2's Avatar
sothpaw2
Amen. Go elsewhere immediately.
To Frozen clutch?
