85 idling at 1500/min when started
Old Dec 10, 2001 | 11:24 AM
Klaus's Avatar
Klaus
Default 85 idling at 1500/min when started
A vette colleague owing an 85 model for 2 months reported the following "failure"...
After starting the engine, it idles at about 1500/min until he pressed the accellerator real hard, just a single short kick - then the engine idles fine.
Is this a malfunction or is it ok?
If it's not ok, any ideas what's wrong and how to fix it?
Thanx,
Klaus
Old Dec 10, 2001 | 03:16 PM
Camvette's Avatar
Camvette
Default Re: 85 idling at 1500/min when started (Klaus)
I had to add a extra spring to the throttle because the return spring grew weak over the years. Easy fix! Could be a good throttle body cleaning would take care of it.
Good Luck!
Old Dec 10, 2001 | 04:08 PM
GRX's Avatar
GRX
It could also be worn bushings on the tb housing causing it to stick a wee bit open.
[Modified by GRX, 8:10 PM 12/10/2001]
Old Dec 11, 2001 | 07:28 PM
Klaus's Avatar
Klaus
Default Re: 85 idling at 1500/min when started (GRX)
Thanks guys,
vette fellow has a winter project now...
save the wave,
Klaus
To 85 idling at 1500/min when started
