Stud Girdle for LT1
Old Dec 10, 2001 | 12:55 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Stud Girdle for LT1
Anyone using a stud girdle on a 92-96 C4? How did you get around using the tall valve covers and the alternator bracket?
Old Dec 10, 2001 | 03:47 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Stud Girdle for LT1 (Vette92)
try here HERE
it is Melrose T-Top cick on the LT1/LT4 covers
[Modified by -=Jeff=-, 1:49 PM 12/10/2001]
Old Dec 10, 2001 | 03:58 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Stud Girdle for LT1 (-=Jeff=-)
Thanks Jeff. I sent them an email with a couple questions on things like breather holes and oil fill openings and bracket issues. We'll see what they send back. The covers look like puke, but if it is functional I can deal with them.
Old Dec 10, 2001 | 04:02 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
They'd look fine with some paint or powder coat.
Cory
Old Dec 10, 2001 | 07:22 PM
Chris@SD's Avatar
Chris@SD
Default Re: Stud Girdle for LT1 (CHarris85Vette)
Cory
Hey Chris! That means that you could put that powder coating kit that you have to use!!! :)
Old Dec 11, 2001 | 01:12 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Stud Girdle for LT1 (Chris@SpeedDemon)
True ;). Still need to find a cheap oven. :D
The only problem I have with this "system" so far is that it comes with the girdle bar and the valve covers for $300, then you have to buy the longer polylocks for the rocker arms. That is another $115. I may just wait on the stud girdle until I can get some break in miles on the motor. I am looking at swapping heads in May as well, so I am not sure this girdle would work with the heads I am looking at. Hate to throw away $400.
[Modified by Vette92, 11:16 AM 12/11/2001]
Old Dec 11, 2001 | 02:24 PM
Chris@SD's Avatar
Chris@SD
What heads will you be going with??? I hope you remember to talk to me! :) :)
Old Dec 11, 2001 | 02:28 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Thinking again about the AFR 227's plus porting them (clean them up) a bit myself. Not sure I can get enough out of these stock casting LT1 heads. Actually, is there ever enough. ;) Quite a few guys like the 227's over on the Camaro board. Kind of a toss up as to put more money into these heads that I don't know will ever really be enough, or start from scratch again with some good castings. Too bad Brodix does not make a Track 1 head for the LT1. If I went with the AFR 220 or 227's I would have to have them milled to match compression with my current heads.
I'll shoot you an email off line.
[Modified by Vette92, 12:32 PM 12/11/2001]
To Stud Girdle for LT1
