Question On Engine Heat
Old Mar 26, 2008 | 04:50 PM
dsimon55's Avatar
dsimon55
Default Question On Engine Heat
I have a stock 85 L98. It seems to run hot.
I replaced the thermostat with a 220 degree.
When just sitting there it seem to go to 240+
The aux fan does come on.
I am going to flush the radiator next.
Is this common? Any ideas what to try next. I would expect it to clime to 220 and thats about all.
Dave
Old Mar 26, 2008 | 04:54 PM
geogolf's Avatar
geogolf
Default heat
you should use a 160 or a 180
Old Mar 26, 2008 | 05:16 PM
kenmohr's Avatar
kenmohr
Check in front of radiator for debris. 220* thermostat is too high in my opinion. If the engine continues to heat up after the thermostat is open and the fan is running you need to look at the air flow to the radiator or coolant flow problems.
Old Mar 26, 2008 | 05:54 PM
vader86's Avatar
vader86
http://temp.corvetteforum.net/c4/vad...erheating.html
http://temp.corvetteforum.net/c4/vader86/160.html
First thing to do is to definitely go back to a 195F stat. Read those links to determine if you wish to go 160 or 180, and determine why its overheating.
Old Mar 26, 2008 | 06:19 PM
El T1's Avatar
El T1
Wow, great links!
So I take it I don't need to get freaked out if I hit 225-230F sitting in traffic, as that's when the above links claim my fan is programmed to come on in the first place...
Old Mar 26, 2008 | 06:38 PM
CFI-EFI's Avatar
CFI-EFI
Yes! You don't have to get freaked by 225°- 230°. For many model years the auxiliary fan doesn't kick on until over 235°. In 1984 the ONLY fan doesn't come on until 238°. Get nervous at 250° and shut it off at 260°. A 220° thermostat is too high. The stock stat, that many people replace is 195°. For normal, everyday driving a 160° stat is too cool for best engine life, economy and power. Also, as mentioned, these cars (C4s) are bottom feeders. The area between the radiator and the condenser gets filled with road garbage. Especially if you have never done it, you may nor be able to detect the problem without removing the radiator. The junk blocks air flow and often is the cause of running hotter them normal.
RACE ON!!!
Old Mar 26, 2008 | 07:12 PM
Demonic85's Avatar
Demonic85
220?? The stock one is a 195. The temps should never go over 232-240, thats when the fans come on.
Old Mar 26, 2008 | 08:29 PM
El T1's Avatar
El T1
Originally Posted by CFI-EFI
Yes! You don't have to get freaked by 225°- 230°. For many model years the auxiliary fan doesn't kick on until over 235°. In 1984 the ONLY fan doesn't come on until 238°. Get nervous at 250° and shut it off at 260°. RACE ON!!!
Thanks (even though you guys have probably had to answer this dozens of times).
IMO: Visually, the analog water temp. guage in a '95 runs darn close to DANGER right were the fan is programmed to kick on. In my Trailblazer SS (LS2), the needle sits rock-solid on 215F, which is in the middle of the gauge...this visual tidbit was throwing me into a worry (needlessly, apparently).
In the Vette, I've been monitoring the digital readout for a better idea of just where I'm at.
To Question On Engine Heat
