injector size for built 358?
Old Mar 26, 2008 | 11:26 PM
1990dtgL98's Avatar
1990dtgL98
St. Jude Donor '10-'11-'12-'13-'14
Default injector size for built 358?
AS you may know, I'm going the heads/cam/superram route, and was wondering what injectors I may need.
The heads flow 280cfm, the cam is a 222/230 duration with .55x lift. I have an AFPR and pink top Bosch injectors right now (22lbs).
If I plan on making peak power at around 5800RPMS, and shifting around 6k, but no higher, so I go with #26 or is what I have ok. I would really like to make sure before I put the superram on, as I don't want to have to take that off...ever.
Old Mar 27, 2008 | 01:27 AM
BAM92's Avatar
BAM92
24 minimum, 30 max.
Old Mar 27, 2008 | 02:09 AM
vader86's Avatar
vader86
I would say between 24 and 30 as well.
But I wouldnt buy anything til I talked with a chip tuner.
Old Mar 27, 2008 | 02:22 AM
racebum's Avatar
racebum
strongly agree with what has been said, talk to a tuner, realize it will fall between 24 and 30. i'm using ford 24s on a very similar motor.
Old Mar 27, 2008 | 04:00 PM
1990dtgL98's Avatar
1990dtgL98
Sounds good.
Thanks guys!
Edit: Does anyone know what the stock impedance and fuel pressure is on them? Also, can you use different impedance injectors than whats stock?
Old Mar 27, 2008 | 04:55 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by 1990dtgL98
Sounds good.
Thanks guys!
On my 1989 it's 16.3 ohms pressure is 42 psi I believe we have the same injectors Delphi Multecs
BTW I vote for the 30 lb injectors and an AFPR.
Old Mar 27, 2008 | 06:24 PM
Kevin Woods's Avatar
Kevin Woods
Originally Posted by BADDUCK
.....BTW I vote for the 30 lb injectors and an AFPR.
I say 30 LBs with stock regulator and a good tune!
KW
Old Mar 27, 2008 | 06:30 PM
BADDUCK's Avatar
BADDUCK
KW
He already has an AFPR which can provide additional fine tuning.
Old Mar 27, 2008 | 06:50 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
30lbs......I'm going 36 with a similar setup. 30 is a slam dunk.
Old Mar 27, 2008 | 11:33 PM
Eddie & the Cruisers's Avatar
What is a 358?
Old Mar 27, 2008 | 11:56 PM
racebum's Avatar
racebum
it's either .030 or .040 over on a 3.50" crank. .40 over on a 3.48 crank is 357
Old Mar 28, 2008 | 01:57 AM
1990dtgL98's Avatar
1990dtgL98
It's a typo....357 (4.04 bore x 3.48 stroke).
Sheesh!
I'll probably wind up going 30's or 32's. No need to go larger, as the only other thing I could add is a supercharger, in which case I'd need bigger than what I should have now.
Old Mar 28, 2008 | 02:11 AM
racebum's Avatar
racebum
make sure to check what psi they are rated at also. the fords are at 39psi so running them at 45psi like i do = something like a 26 {guessing} i know with pressure going up, so does the fuel delivery capability. i've actually seen as much as 390rwhp 430ftlb on ford 24s, 30s offer a nice safety margin though. i think you could go either direction and be just fine. before you buy anything, talk to whoever is going to tune the car and ask their preference.
Old Mar 28, 2008 | 07:11 AM
anesthes's Avatar
anesthes
Sheesh!
It's actually 356.5, but I've seen most people call it 358 too.
-- Joe
Old Mar 28, 2008 | 07:13 AM
anesthes's Avatar
anesthes
Thats a myth. We've had numerous ford injectors tested by Cruzin Performance, and they were all rated as SAE 43.5psi. The myth revolves around the fact that ford runs a lower rail pressure.
I can link you to the test charts we posted years back.
-- Joe
Old Mar 28, 2008 | 11:28 PM
Thanks. I just always referred to it as .030 or .040 over.
Old Mar 29, 2008 | 02:39 AM
racebum's Avatar
racebum
-- Joe
seriously? wow, i had no idea, i'm sure you've heard the 39psi more than one. do you know off hand about how many psi is needed for 1 lb gain in injector size? say 24lb@44psi, what would it take to hit 25lb, 26 etc
Old Mar 29, 2008 | 08:58 AM
anesthes's Avatar
anesthes
Yes.
http://www.rceng.com/technical.aspx
So, lets say you need a 26# injector, but you have 24# injectors. All injectors are rated at 43.5PSI, simply raising the pressure to 51 psi will
make a 24# injector deliver 26# of fuel per hour.
Be careful, because you can exceed the ability of the pump as pressure goes up. The pumps volume is rated at 43.5 psi as well, so as pressure at the rail goes up the pumps volume will go down. If the volume goes down beyond the flow requirements you'll run lean.
for example:
http://www.autoperformanceengineerin...l/fpspecs.html
This shows how the volume relates to the pressure. A stock GM fuel pump is about 160lph, or 42 gallons per hour. We know a gallon of gas is about 6 lbs, so roughly 252 lbs per hour.
So we know the stock fuel pump has the ability to drive 8 31# injectors
at 43.5psi to go static.
Now glancing at our chart, we see that by bumping up the fuel pressure
to 50 psi, we take a hit of about 10%. So now our volume capability is only 226 lbs per hour, or 28# per injector.
This is important, because once you get to 60psi you can only deliver 25# per injector, meaning you've exceeded the flow ability of the pump at that high a pressure, so you're no longer making up for smaller injectors. (since now your delivering less fuel at 60psi than you were at 50psi)
-- Joe
Old Mar 29, 2008 | 02:24 PM
racebum's Avatar
racebum
that was an awesome reply and it makes complete sense the longer i think about it.
To injector size for built 358?
