MAF location?
Old Mar 27, 2008 | 01:35 AM
rtracy's Avatar
rtracy
Default MAF location?
Where is everyone putting the MAF sensor on supercharged cars? I have a 95 with a procharger and mine is located between the air filter and surge tube in the right front fender well. Is there a better location?
Old Mar 27, 2008 | 09:22 AM
rtracy's Avatar
rtracy
Are anyone running the MAF sensor on the pressure side and how are you doing it? On my set up I have a IAT sensor between the intercooler and the throttle body.
What I was thinking is I could relocate the IAT sensor and put the MAF in it's place. Could I relocate the IAT sensor somewhere else? I am told that the MAF is reading way to much air at idle.
Old Mar 27, 2008 | 10:32 AM
Bam's Avatar
Bam
My MAF is at the passenger front under the headlight, just in back of the air filter. Had to use a smaller coolant overflow tank.
Old Mar 28, 2008 | 12:30 AM
rtracy's Avatar
rtracy
That is where I had mine but it is picking up way to much air at idle I think because of the surge tube. I need some idea's on where to relocate it. I was going to put it up by the throttle body but it is 4" tube and the MAF is 3 1/2".
Old Mar 28, 2008 | 09:47 PM
C5rider's Avatar
C5rider
Would there be any possibility of using a newer MAF? I know that in 2000 or 2001, GM changed the MAF. Haven't played with them much but if they are bigger, maybe it would fit better? I believe they both work off of frequency, right? I probably know enough to be dangerous here.
I've got an LS style MAF on my LT motor in my '85. I'm using an '89 computer with a MAF translator. Even gives me some tunability at various RPM and under three different load settings. Check out www.maftpro.com for more info. I like what it does for me. Then again, I would have been forced to use the bosch unit if I didn't have this, due to that frequency/voltage differential between the Tune port stuff and the LT and up.
Old Mar 30, 2008 | 11:59 AM
rtracy's Avatar
rtracy
Bam, do you have any logging software like DataMaster?
Old Mar 31, 2008 | 04:39 PM
silver86's Avatar
silver86
Mine is on the pressure side
Old Mar 31, 2008 | 06:05 PM
Bam's Avatar
Bam
no, but now i am wondering about the pressure side may be good but no intercooler? no where to put MAF like that on my setup. Still need to research more.
Old Apr 4, 2008 | 01:38 PM
rtracy's Avatar
rtracy
Man, I just got done relocateing the MAF. Had to change the worm clamps out for some t-bolt clamps. It seems like for 5K Procharger could put a little bit better parts in there systems. Like the clamps, by the time you get them tite enough so they don't leak if you have to take it back appart you need to replace the clamps. Also I think they can do better on there hose. I just bought two silicone 45 degree reducers 4" to 3.5" for $40. Nice hose. And I am begining to wonder about the intercooler. If I knew then what I know now I would have got the system without all of the intercooler stuff. (Tubing, intercooler and hose). Will see when I dyno it.
Old Apr 4, 2008 | 06:54 PM
Bam's Avatar
Bam
were you having any trouble with idle or WOT with it the way you had it? I sure would like to know, thanks
Old Apr 5, 2008 | 12:00 AM
rtracy's Avatar
rtracy
I had a rich problem at idle and criuse. I'm not sure at WOT because I don't have a AFR meter. I believe what happens is the surge valve blows unused air back out into the intake hose which is already filled with air so it blows the air out the MAF and air filter causeing the MAF to give a false reading of to much air causeing the PCM to richen the the mixture.
You can tell if it is running rich by pulling your plugs. If there black it's rich. Hope this helps.
Old Apr 7, 2008 | 11:14 PM
Bam's Avatar
Bam
Thanks it does. I hope you can get your prob fixed and get back to what it's all about, driving like you stole it.
To MAF location?
