Trailing and camber rod brackets!!!!!!!!!!!!!!!!!
Old Apr 9, 2008 | 04:51 PM
  #41
SuperL98's Avatar
SuperL98
I've found that "AntiSquat" is a very poorly understood and sometimes volatile topic.
Drag racers believe the more (over 100%) the better for traction, Road racers seam to think less (less that 100%) is better for traction.
100% being no rear lift or squat on acceleration (neutral).
Can’t both be right … or can they?
The best discussion I’ve found about it, to date, is here:
http://www.eng-tips.com/viewthread.c...105947&page=12
It’s a tuff read, and they go off subject a bit, but some good information in it
Old Apr 9, 2008 | 06:14 PM
  #42
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Originally Posted by chevyforever
@Randy
can you tell me, when the next brackets (both camber and trailing) are available? And how much would be the shipping to germany (zip code 04539)?
Thanks a lot!
Regards
Rico
Rico,
I am still waiting on a few more of the 16 to trickle in here. I will put you on the list for the next go around.
Randy
Old Apr 9, 2008 | 06:17 PM
  #43
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I didn't read all of the link. But I know one thing from growing up and living as a full time racer. Many different ideas, and theorys cross the finish line first. Go to the local dirt track and look at how many different ways a car can be setup.
Randy
Old Apr 10, 2008 | 06:28 AM
  #44
SuperL98's Avatar
SuperL98
Randy
Yes, very true Randy … I agree
But here, when you think more about it, the two conditions can be very different.
The Drag Racer has & is:
* Tall, soft flexible sidewall, very sticky tires (slicks).
* Accelerating from a dead stop (chassis settled).
* Relative smooth, sticky pavement.
* Going in a straight line.
These things favor a very quick responding (for reaction time), hard-hitting application of power, dynamically stiffer rear suspension (High Anti Squat). And also can better tolerate the quick unloading reaction that comes after the initial launch (flexible sidewall again).
The Road Racer has & is:
* Shorter, very stiff sidewall, not so sticky tires (compared to slicks).
* Usually accelerating from low speed out of a corner, with a very unsettled chassis.
* Typically a bumpy and sandy pavement.
* Maybe going straight, usually turning into the next corner.
These conditions usually favor a softer application of power and a more dynamically compliant rear suspension (Low Anti Squat).
This supports the DRM theory that softer, lower antisquat (from your trailing arm relocation) is good thing for road racers, and maybe street tire drag racers.
Probably not so good for the all out, slicked, drag car.
Old Apr 10, 2008 | 03:12 PM
  #45
DOCTOR J's Avatar
DOCTOR J
He read the post from the guy in London, and from the top of his mind, that his comments are correct. But not 100 percent sure. Randy
A. Thanks for the response. I concur with that comment - repeated here from 2005:
Originally Posted by ukchevybuilder
re anti squat
This is a very interesting and informative thread. I can only offer two comments
1) I have seen 18" shown as the CG height for a C4 in a book, many of whose illustrations looked as if they came from GM. The front roll center was, I think, 4.6" and rear RC was 8". From my own calculations I would support the 18" CG number rather than 15".
2) A lot of road cars have anti dive and anti squat because with relatively soft spring rates fore and aft weight transfer uses up a lot of suspension movement before you hit a bump or generate roll angles. For a track car with harder springs to limit roll the relative benefit of anti dive is less. The traditional argument against anti dive/squat on track cars is that it affects the transient handling by diverting some of the weight transfer to the "solid" method through the links as opposed to the springs. This, it has been argued, reduces "feel"and complicates roll stiffness and reduces the effective control power of the dampers.. I could guess that this might be a particular issue on autocrossing because of all the short duration transients involved mean that the dampers are the predominant control factor.
In the future, if I don't do something. me sooner then later!!!
B. I would have done, but you haven't answered the two e-mails I sent you at the time -
one to you @ DRM and another @CF address in your profile. Thanks anyway, you can
delete them from your 'To Do' list now.
Old Apr 10, 2008 | 08:32 PM
  #46
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by Slalom4me
In Randy's initial post (1/24) asking for expressions of interest
he gave a general overview of the benefits of the two sets of brackets.
Trailing and camber rod brackets, gauging interest
I do not recall anyone ever posting what the details of the changes
entail (geometry, precision measurements). My vote is that since this
amounts to someone's Intellectual Property, the details ought not be
displayed in the public domain unless the vendor chooses to do so.
I missed the earlier post that gave the general trend of the changes. I appreciate your forwarding the original thread posting.
Regarding details of the part, and intellectual property, I disagree with your position. There is a lot of snake oil being sold in the Corvette aftermarket industry (I am not referring to DRM in this instance), and I see nothing wrong with asking how a new part is different from the old part. I'm going to take a wild guess, and assume you wouldn't buy a camshaft without all the specs to compare it to your original cam. Just saying "it's better" or "it's faster" doesn't cut it anymore.
(Disclaimer: I'm a design engineer by trade. I'm used to data, rather than generalities.)
Just my opinion.
Old Apr 11, 2008 | 11:39 AM
  #47
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Just my opinion.
This is a very hard subject. We 100 percent agree this aftermarket car world is filled with snake oil and bling only parts. There is a lot of Corvette experts now days also and more and more borrowed information to the point of being stolen.
Suspensions are one of the most important and hardest to engineer part of the car. It's even harder for internet talk. The engine are easiest to measure and internet it and are pretty simple to a point. Why don't you see dyno numbers from our shop?
I have never seen shock valving numbers on this forum, well besides drag guys talking about the "90-10". Same type of a deal with our trailing and camber rod brackets.
We made this parts for our own racecars, then installed them into street cars that get raced. Same results happened, more tire contact with the road and more weight to get the 3000 plus pound cars coming out of the corners.
So how does our company engineer a products. Well we don't spend time on the computer. We spend our time in the shop measuring, change measure, change measure again. Then bring a bunch of stuff to the track and race it. We were very lucky to be able to test products like we have. Back in the C4 days the tire companies paid for a lot of our testing which gave us a unfair advantage! Also we have had very good test drivers in our cars, they may not be the fastest but they can give feedback. We found working with tire companies is the best way of going faster. Those guys know more about the car's suspension then anyone else. Why? Because it is important to have the suspension working with the tire, unlike a lot of people now days making a tire work with their suspensions.
For $200 bucks isn't it worth the risk of going faster!!!!!!!!!!!!!
Randy
www.dougrippie.com
Old Apr 11, 2008 | 02:40 PM
  #48
rickneworleansla's Avatar
rickneworleansla
I hope you will continue to offer these in the coming months/year. After my $3,200 transmission bill is paid off around August I will be ordering a set.
Old Apr 16, 2008 | 10:16 AM
  #49
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I sent some more PMs today. I have a couple more sets around. And more being made.
Randy
I have a ton of camber brackets for the early cars.
Old Apr 20, 2008 | 05:43 PM
  #50
Snakecharmer383's Avatar
Snakecharmer383
I recieved my set of both. I thought the total was $200.00?? Mine was $215.00 is that extra 15 for shipping??
Old Apr 21, 2008 | 10:20 AM
  #51
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Yes the extra 15 bucks was for shipping.
Randy
Old May 4, 2008 | 02:03 PM
  #52
Lister's Avatar
Lister
Hi Randy,
I am interested in buying a set of the camber brackets but do have a question on how effective they would be for my application, which you may or may not be able to answer. I have a replica of the 1958 Lister Corvette that uses the early C4 suspension. The car is only 2000 lbs and I know that some of the rear components have been modified/narrowed from stock by the builder (leaf spring is shorter, camber rods not stock, not sure about half-shafts). Other components are completely stock (knuckles, trailing arms, toe rods). Any thoughts? I am willing to take some measurements and send them to you off line if it would help in your response.
Also I just checked your website and it indicates "1984-87 Corvette 22-020 Out of stock" for the camber brackets. Are you just giving us the first crack at them before you open it up for the general public?
Thanks,
Alan
