95 Brake Fluid Flushing
Old Dec 10, 2001 | 09:26 PM
z06dailydriver's Avatar
z06dailydriver
Default 95 Brake Fluid Flushing
I'm going to change the fluid in the brake system on my 95 after 87K miles. It needs it. Using the pump the brakes and open the bleeder screws method, is there any other detail I need to take care of ? ie anti lock brake system?
Old Dec 11, 2001 | 12:49 PM
John Row's Avatar
John Row
Default Re: 95 Brake Fluid Flushing (z06dailydriver)
There is a bleed valve on the ABS body. It's on the side near the top of the unit. Just be sure you don't run the reservoir out of fluid.
Old Dec 11, 2001 | 02:09 PM
4GTWRK's Avatar
4GTWRK
Don't allow the pedal to go all the way to the floor, it pushes the seals into an area inside the master cylinder that never is used. Sometimes there are contaminates there that will scratch the seals and make them leak.
Dave
Old Dec 11, 2001 | 02:31 PM
JonM's Avatar
JonM
You shouldn't "Pump" the breaks when you bleed them, just hold pressure on the pedal. Start with the Left Rear, Right Rear, Left Front, and Right Front. Do NOT evacuate the system of fluid; Drain the reservoir with a turkey baster or paper towel. Clean it out then run fresh fluid through the system. Do NOT reuse the fluid you run through the system. While you are at it you might as well flush the Slave cylinder if you have one. (Manual transmission)
Old Dec 14, 2001 | 07:18 PM
z06dailydriver
Default Re: 95 Brake Fluid Flushing (JonM)
A belated thanks to all your helpful comments. i was out of town and just got back. I 'll try it out tomorrow!
Old Dec 14, 2001 | 09:34 PM
ROADRACER_'s Avatar
ROADRACER_
Default Re: 95 Brake Fluid Flushing (John Row)
John
What about bleeding the system with a vacuum pump sucking the fluid out of the bleeder screws method, is there anything special I need to know or need to do besides starting with the right rear first, and then working it to the closest to the reservoir which would be the drivers side last? Is there anything I have to with the ABS unit at all or can I just ignore that and go about just bleeding from the screws and fill the reservoir as I go? Let me know if I need to do anything other than that.
Old Dec 15, 2001 | 12:26 AM
C4396roadster's Avatar
C4396roadster
I was at the shop the other day and seen my mechanic with a new gadget that attaches to the compressor what it does is pressurize the sys and vacuum empties out the old stuff and at the same time doing a leakdown on the sys itself he said this is the newest way to completely changeout the old fluids antifreeze brake fluid etc
Old Dec 15, 2001 | 12:47 AM
SLICKMAN's Avatar
SLICKMAN
Default Re: 95 Brake Fluid Flushing (ROADRACER_)
Here is what I do.. If you have an air compressor, you can make setup that will attach to the master cyl and all you have to do is go to each wheel and open the valve untill clean fluid comes out. I have used the hand pump as well and it works. You just have to keep pumping, closing the valve, filling the master cyl...
If you get a piece of alum the size of the master cyl, drill two holes in it that will be over each cyl.. Set these up with fittings that you can screw a hose onto (and plug the other). Now setup a container that will hold about a quart of fluid out of a piece of pipe. Drill a hole in each end cap, install a fitting on one that will connect to the alum plate you made. Connect the other (from the top) to the air compressor with a fitting. Make sure you hang it so the fluid can feed down. Adjust the air compressor to be at about 20 to 30 lbs of pressure. Then bleed away!! The hardest part is making the system but, its a great setup and only cost about $30.. :cheers:
By the way, I forgot one thing..... The alum plate is held on with a vice clamp whci I had around and you need a piece of rubber about 1/8 thk to seal it with the master cyl.
Boy, did I make this long or what!! :lol:
John
[Modified by 1991C4, 11:50 PM 12/14/2001]
To 95 Brake Fluid Flushing
