Engine Mods
Old Mar 30, 2008 | 05:14 AM
BOBSTOY01's Avatar
BOBSTOY01
Default Engine Mods
I have had my 89vette with an automatic with 75000 origional miles.I don't intend to race but would like to get the power out of it that it was designed to do without any internal engine work. What are some of the bolt on parts can I put on it. I've already started on the exaust and I put an msd ignition and wires. How much do you think I will gain? Thanks for any info you can give me.
Old Mar 30, 2008 | 05:51 AM
1988covette's Avatar
1988covette
Cruising
chip it and add 60 HP right away. umm do intake thats pretty easy. headers arent that hard to do. i would say cam but you dont want to do anything internal. twin turbo it, that would make it fast.
Old Mar 30, 2008 | 07:29 AM
rodj's Avatar
rodj
Must be good drugs in VA
How about one of them electric superchargers while you are at it?
25% more Hp for only $69.99
Add a TB air foil , TPS switch and those special vortex exhaust tips ; you can have 500Hp for only $200
Old Mar 30, 2008 | 08:17 AM
1988covette
Cruising
wtf are you talking about. you chip it and it will add 60 HP. go look a mamotorworks.com they have chips for like 300$ that will add like 60 hp
Old Mar 30, 2008 | 08:23 AM
Muffin's Avatar
Muffin
Not exactly. They advertise thy have chips that will add 60 hp. Find someone with dyno slips that will prove it.
Old Mar 30, 2008 | 08:58 AM
Iroc57's Avatar
Iroc57
It is a good idea to post from experience and not what you read in an advertisement. Please post your dyno slip with your chip installed to support your recommendation to the OP
Old Mar 30, 2008 | 09:31 AM
cv67's Avatar
cv67
St. Jude Donor '05
Long tube headers
2.5" Catback
1.6 rockers/springs
Dyno tune
Old Mar 30, 2008 | 09:57 AM
aboatguy's Avatar
aboatguy
You need to do a little more research or you are going to be very disappointed with your performance upgrades.
Mike
Long tube headers
2.5" Catback
1.6 rockers/springs
Dyno tune
if you can find a stock LT1 catback for cheap it is a good upgrade for the L98 cars (dual 2 3/4" pipe!
However, if you want some real power from an L98 your going to have to ditch the intake, and or get into the engine.
*caveat this is the 21st century folks, 300 hp is not close to real power.
Mike
Old Mar 30, 2008 | 10:10 AM
Z51L9889's Avatar
Z51L9889
The exhaust on TPI cars is pretty restrictive. Cuisinart's advice is right on the money. Do the exhaust first, get it tuned, and see if the power level is where you want it. High flow intake parts will give you a decent bump in power once the exhaust is complete, but you will have to make internal changes (cam, head work) to realize their full potential.
Old Mar 30, 2008 | 10:45 AM
Aardwolf's Avatar
Aardwolf
Sell the MSD for money to use on real mods, also stay away from silly chips. A custom tune can help once you have done a bunch of mods. You mentioned exhaust mods, did you put on headers? After exhaust then a better intake will help. Under drive pulleys are a nice bolt on too.
Old Mar 30, 2008 | 10:48 AM
Demonic85's Avatar
Demonic85
Long tube headers
2.5" Catback
1.6 rockers/springs
Dyno tune
plenty of "seat of the pants" power right there. Porting the intake, adding heads, and a cam is even better
Old Mar 30, 2008 | 10:59 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
A couple of free mods will help a little.
1) Remove the frisbee
2) Bypass the throttle body
Also dual outlet performance mufflers and removing the front cats will help.
Old Mar 30, 2008 | 12:24 PM
vader86's Avatar
vader86
Never listen to this guy.
Click my name, you'll see a link to my website. Read it and make your own determination of what you want to do.
Old Mar 30, 2008 | 12:30 PM
TA's Avatar
TA
If only it were that easy
Old Mar 30, 2008 | 12:37 PM
mseven's Avatar
mseven
Old Mar 30, 2008 | 12:45 PM
John A. Marker's Avatar
John A. Marker
LISTEN TO VADER. He knows his s**t about our engines. Do your research and start with his web site then use the search function about specific modifications.
With the L98, exhaust modifications (high flow cat, larger pipes, headers if your state allows them, duel outlet mufflers) really helps. That gets the air OUT. Then concentrate on getting the air IN, high flow runners, better plenum, better intake manifold. Then if you can, heads and roller rockers. You can get alot of power without touching the bottom end. You will never get the power of the new Corvettes, but you will have fun driving it.
Old Mar 30, 2008 | 01:08 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Default Chip It???
Right now my 87 Roadster is in the shop having long tube Hooker hedders, stainless steel dyno max High performance mufflers with y pipe,
SLP C.A.I. and removing cats. I was going to do all the work my self however due to surgery I will be off work for several weeks and do not want to miss any good weather driving.
I am going to chip it for the BIG power gain.
I will buy a Bag of Fito Lay Chips and have some friends over to celebrate when my car and myself are all back together.
To Engine Mods
Old Mar 30, 2008 | 01:13 PM
John A. Marker
I like this option to "CHIP IT". You will get more for your money.....friends to share with. Bet you won't let them drive your car.
Let them ride, but time to get plastic seat covers on the passanger seat
Old Mar 30, 2008 | 05:37 PM
87Beast's Avatar
87Beast
If you want some power you gotta get inside the engine. A head/cam/header change has turned my car into a rocket. Next project is the intake when I win the lottery .
As Vader says read his site...get the chip (customized to YOUR car) once you modify your car or you'll end up paying someone kid's college tuition. (Look at what our buddy at Mid America (or ? it's called now) has in his garages.)
Beware there are companies/websites that feed you bull$*&t about adding hp/tq for their products, so most of these bolt ons will do nothing but drain your wallet, so be careful what you read.
Old Mar 30, 2008 | 06:31 PM
aboatguy's Avatar
aboatguy
They don't lie they usually say (UP TO XXX HP) however, some of those up to numbers had to be on a previously malfunctioning car, and the new performance part fixed the problem.
I can't see 60 HP in any mail order tune on a stock engine. Now with intake, cam, heads, exhaust I can see the tune boosting the performance in the double digits.
JMHO
Mike
