Changing waterpump
Old Mar 31, 2008 | 08:35 AM
NoTiNg's Avatar
NoTiNg
3rd Gear
Default Changing waterpump
I´m a little bit of a rookie. Does anyone knows how to change the waterpump in an c4 1990? Is it a hard thing to do?
Old Mar 31, 2008 | 10:12 AM
wro87's Avatar
wro87
Not that big of a deal. Just get the belt out of the way and the intake then you simple unbolt the pully then the pump and then do it in reverse to bolt on. I would change the thermastat also with a lower temp to help on cooling. I would wash the front of the engine down first to get all the crud out if it should need it .
Good Luck wro87
Old Mar 31, 2008 | 10:15 AM
Corvette Chris's Avatar
Corvette Chris
Wasn't too bad of a job. But I did it when I was replacing my intake manifold gaskets. One of those while I'm at it deals.
What pump are you going to put on?
Old Mar 31, 2008 | 10:54 AM
NoTiNg's Avatar
NoTiNg
3rd Gear
Ok...Maybe I have some luck for once in my life... in other case the whole car will burn down to the ground...
I don´t quite know what pump it´s gona be for the moment. I´m ordered it from a swedish dealer, specialist in amercian cars, so I hope he knows what he is doing. I´m going to get the pump tomorrow... I´ll get back whith more information about it. Thanks for fast answears!!!!
Old Mar 31, 2008 | 11:20 AM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
You might want to replace the opti at the same time...just saying...
Old Mar 31, 2008 | 11:29 AM
CFI-EFI's Avatar
CFI-EFI
On a 1990 car??? I'm just saying...
RACE ON!!!
Old Mar 31, 2008 | 11:34 AM
Corvette Chris
Old Mar 31, 2008 | 11:43 AM
jimmymack's Avatar
jimmymack
My bad, brain lock up, thought it said 95...will look into a new set of glasses later today
To Changing waterpump
