LT1 header thread size
Old Mar 31, 2008 | 01:07 PM
anesthes's Avatar
anesthes
Default LT1 header thread size
What size threads are these on the AIR tubes? I bought so 2061 headers, and need to hook up the AIR tubes. It looks like a fine thread.
The '87 stuff won't fit/is different.
-- Joe
Old Mar 31, 2008 | 01:15 PM
F1Fan's Avatar
F1Fan
My '95 uses an M21 thread for the air injection ports on the headers.
I was struggling to find a fix for this myself, but on another site, someone had suggested using an M21 oil drain plug for it. Or you can find a plug/disc/etc that can block the hole and then cut the old fittings off the air pipes and use those to hold it down.
Old Mar 31, 2008 | 01:29 PM
anesthes's Avatar
anesthes
M21 drain plug? Sounds good. I'll dill out the center and weld a 90* to it.
Thanks a bunch!
-- Joe
Old Mar 31, 2008 | 10:19 PM
Eddie & the Cruisers's Avatar
The left and right are a different size on a '94 LT1 or is it the tube size that's different?
Old Apr 1, 2008 | 09:58 PM
anesthes's Avatar
anesthes
It ended up being 22MM on both sides.
-- Joe
Old Apr 1, 2008 | 10:57 PM
C4forlife's Avatar
C4forlife
Default drain plug
I got mine at oreilly auto in the area where they have all the generic stuff like window cranks vacuum tubing etc. The application is a cummins diesel dodge.
Old Apr 2, 2008 | 06:56 AM
anesthes's Avatar
anesthes
Good to know! I searched through a bin of fittings for 10 minutes. They didn't end up charging me for them.
-- Joe
To LT1 header thread size
