infl rest code
Old Mar 31, 2008 | 02:02 PM
littleredcorvette88's Avatar
littleredcorvette88
Default infl rest code
infl rest code has just popped up does anybody know what to do to fix this...and do i need a code reader to reset it after i am done fixing it?
thanks
Old Mar 31, 2008 | 02:12 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
To fix it refer to the Factory Service manual and follow the diagnostic charts very carefully or you may pop the air bag.
Old Mar 31, 2008 | 04:16 PM
pipe's Avatar
pipe
Mid America makes a neat little tool to erase the code and light providing none of the frame sensors are bad. What year is your car? The tool from Mid America is cheap $20 bucks and gives the specs for OHMing the sensors on the frame and a list of the codes and their meaning. If one of the sensors is faulty they are only $60 bucks from GM. Give me some more info and i'll try to help ya more. Pipe
Old Mar 31, 2008 | 08:50 PM
littleredcorvette88
its a 91 .... i have no idea it a sensor is bad...thanks...what is the name of that tool called?
Old Apr 1, 2008 | 10:51 PM
pipe's Avatar
pipe
Mmm this usually only happens on 90 vette's but it could on others I guess. It just says INFL REST reset tool. It's a small momentary contact button that hooks to your ALDL Connector under the dash near your right leg and also gives the code numbers and the procedure for erasing the code and light. Also gives the specs for OHMing the Sensors. It's only $20 bucks. Remember DISCONECT YOUR BATTERY when replacing the Sensors or OHMing them. KEEP ME POSTED Pipe
To infl rest code
