cooling fan problems
Old Mar 31, 2008 | 03:04 PM
dcmicro's Avatar
dcmicro
2nd Gear
Default cooling fan problems
Hi i have a 87 corvette, in which the cooling fan will not turn, i have replaced the ECM, cooling fan relay, and temp switch in the block but it still will not come on when it get hot, is there anything else i can check or replace, when i short out the relay connector the fan will come on, so i am at a lost here, can anyone help!!
derek
Old Mar 31, 2008 | 09:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The coolant temp sensor is located below the TB in the intake base. This is the sensor that the ECM uses to determine when to turn on the main fan.
To test this sensor measure the resistance cold and hot; the resistance value should drop greatly when hot.
To test that the ECM can bring on the main fan, open the small connector in the A/C coolant line (near the dip stick tube) and the fan should run.
Old Mar 31, 2008 | 09:33 PM
CFI-EFI's Avatar
CFI-EFI
The only temp sensor in the block is just above the oil filter at the left rear of the block. It is for the oil temperature. The main fan is controlled by the ECM. It uses the same sensor 65Z01 pointed out for all it's functions, including cold start mixture and cold idle speed. Are you getting the engine warm enough for the ECM to switch the fan on?
RACE ON!!!
Old Mar 31, 2008 | 11:35 PM
jfb's Avatar
jfb
The main fan comes on at 228F and the aux fan at 238F. The temperature switch between cylinders 2 and 4 only turns on the auxilliary fan. Ignition in run, if you ground the green/wh wire on the fan relay, the main fan should run. Check the 3 amp c. fan fuse with an ohmeter.
Old Apr 1, 2008 | 02:32 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Don't you mean 1 and 3?
Old Apr 1, 2008 | 02:46 PM
CFI-EFI's Avatar
CFI-EFI
He must. The heads aren't drilled and tapped, there. The aux fan switch, if the car has RPO# B4P, is in the left head between the front two (#1 & #3) spark plugs. No B4P? The hole has a plug in it. Either way, that has no bearing on the main fan operation.
RACE ON!!!
Old Apr 1, 2008 | 03:16 PM
jfb's Avatar
jfb
One of these days I am going to learn to either count cylinders correctly or stop posting late at night.
Old Apr 8, 2008 | 11:11 AM
dcmicro's Avatar
dcmicro
2nd Gear
thank you for all your help i will try the coolant temp sensor under the TB. That is the only sensor that i have not replaced, the air conditoniar compressor doesn't work, does that have anything to do with the main fan not coming also?
Old Apr 8, 2008 | 11:27 AM
CFI-EFI's Avatar
CFI-EFI
Quit throwing parts at it. I don't know what "temp switch in the block" you replaced, but that and changing the "ECM, cooling fan relay" all haven't helped. Does the engine have a fast, cold idle? If it does, that is a sign that the ECT sensor under the TB is working. If in doubt, it can be tested. As jfb posted, the ECM doesn't start the fan until the coolant reaches 228°. Are you getting it warm enough to call for the fan?
The fan should also come on when the ECM receives a signal from the A/C pressure switch, but with the air, off, or with a bad compressor there is no interference with the thermal operation of the fan.
RACE ON!!!
To cooling fan problems
