Battery Draw - '87
Old Apr 1, 2008 | 12:01 PM
AKS Racing's Avatar
AKS Racing
Default Battery Draw - '87
This is probably an easy one for some of you out there.
I went to start the '87 Vette in early March, and it was completely dead after sitting for a few weeks. New Optima in early January. Other one lasted ~7 years. It just started getting weak, so I replaced it.
I put the trickle charger on it and after ~ 4hrs charging it started fine. I noticed after I was done driving that when I went to re-start (you must turn the key on and let it go through a complete fuel pump energize cycle, then start on 2nd energize, as it pulls a lot of fuel and f.p. will drop to ~15 psi when cranking), there was a strange "hum" after the fuel pump circuit shut down without car running. It sounds like it might be coming from the R rear area, and almost sounds like the hum from the radio speakers. I made sure the radio was off. Put the car away amd turned off the battery disconnect.
I pushed the car out in mid/late March and then switched the battery cutoff to the "ON" position. The key was not in the ignition, but that same "hum" was present. The car started no issue.
I think the "hum" is what drained the battery. Any thoughts on what the "hum" may be in the R rear or rear area of the car? Thoughts on how to pimpoint the issue?
Thanks in advance,
Aaron
Old Apr 1, 2008 | 12:06 PM
supersmoothpunk's Avatar
supersmoothpunk
a buddah meditating? look for a big fat guy.
Old Apr 1, 2008 | 02:02 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Got Bose? If so, I'd check the Relay.
Old Apr 1, 2008 | 03:18 PM
jfb's Avatar
jfb
Fuel pump.
Old Apr 1, 2008 | 04:02 PM
Harryscarlot's Avatar
Harryscarlot
only a few things that can hum back there. the fuel pump, bose amps/relay, antenna motor on left side, and my high school sweetheart .....I'd start pulling fuses and you'll at least find which circuit. -Harry
Old Apr 1, 2008 | 04:59 PM
AKS Racing's Avatar
AKS Racing
Thanks for the reply guys:
Well the fuel pump is not the answer, as there is no mistaking the sound of the Weldon. The radio was off, so the power antenae was also down, so I think that is out. Not the HS sweatheart, as I would definitely know that sensation.
Where is the Bose relay located?
Thanks again for the replies.
Aaron
Old Apr 1, 2008 | 05:04 PM
Harryscarlot
Aaron
don't assume your antenna is not the culprit.
pull the radio fuse and see if it goes away. I don't have the FSM in front of me, but someone w/ radio knowledge hopefully chimes in on your other relay question.
Old Apr 1, 2008 | 05:27 PM
AKS Racing's Avatar
AKS Racing
The antenna still works up and down so I assumed that it was not the power antenna relay. You know what they say about assumptions...
Old Apr 1, 2008 | 05:30 PM
Harryscarlot
well alright, I'd assume that your antenna is working OK too. plus the noise you say is on your right side (pass).
To Battery Draw - '87
