89 Coupe antenna
Old Dec 11, 2001 | 01:07 PM
RickSnow's Avatar
RickSnow
Default 89 Coupe antenna
For some reason my antenna won't retract. No sound from antenna motor. Could it be something other than having to replace the motor? Thanks.
Old Dec 11, 2001 | 02:01 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: 89 Coupe antenna (RickSnow)
There is a relay in the back near the hatch latch that could be bad.
THat would be less expensive than replacing the entire antenna (you can't just replace the motor).
Old Dec 11, 2001 | 03:59 PM
SunCr's Avatar
SunCr
Just replaced my third or fourth one (antenna that is). For me, the Relay has always checked out ok. If you want to test yours further, apply steady pressure to the top of the mast and see if it will retract. What happens is the plastic strap that connects the mast to the motor snaps and jams inside of the housing. I believe a kit is available to replace the strap and/or the mast, but I find it just as easy to replace the whole stupid thing.
Old Dec 11, 2001 | 04:11 PM
pablocruise's Avatar
pablocruise
In my case, it was just grime that accumulated and made it slow then eventually stick. Just wiped it down and cleaned it when the radio was on. Also maybe the ground?
Welcome aboard. Looks like you're new here. :cheers: Wave at the other vettes on the road and let's see some pictures of your car! :seeya
[Modified by 89 Paul in cal, 12:12 PM 12/11/2001]
Old Dec 11, 2001 | 04:32 PM
RickSnow's Avatar
RickSnow
Default Re: 89 Coupe antenna (89 Paul in cal)
Thanks for your help. I'll probably check it out this weekend. I am new here. I spend most of my time on my 66 427/390 and my 67 427/435. Thanks again.
To 89 Coupe antenna
