After that the car started running like sh*t. It actually ran better with the MAF sensor unplugged (but never a 14.098). Check engine light was coming on , then going off sometimes...
Seems like the car was shutting down my acceleration past 4000 rpms...
If that MAF sensor is bad grab a reman at Autozone asap, make sure to replace the maf burnoff relay at the same time .
Mine had done that intermittently,(98% of time time it was fine) displayed no codes. By the time I figured it out it was too late, MAF made it run SUPER lean and ate up a head gasket over time .When it acted up at higher rpm it "bogged", kind lof like dragging the brakes. This was over a good period of time, wouldnt sweat it if I were you. not saying this will happen to you, just dont let it go.
Yes, kinda bogging feeling. The bummer is, I replaced the MAF sensor from autozone about a year ago. I keep reading about checking the relay ( from searches) , I'll replace that for sure and check the codes ASAP. Appreciate the help...!
Is your car an automatic? What were your trap speeds?
