Auto Transmission 3/4 Clutch Pack Question
I have a 1996 coupe where I am rebuilding the transmission myself. I notice that some rebuild kits have the alto Red 9 pack clutch and steels, while others have an 8 pack clutch and steel.
My question is, which is better for high horsepower applications (planning a 402 stroker next year)......the 8 pack or 9 pack????
Who has the best price quality master rebuild kits? thanks in advance!
The frictions and steels vary depending on the input drum.
Use a raybestos z pack for the 3-4 pack
I use the 8 blue frictions and koelene steels for the 3-4 clutch with a selective backing plate. I get my stuff from Transtar out of Cleveland. Are you putting in the Beast reaction shell? Trans-Go kit?
Bruce
Bruce
Hi
Yes, I am putting in a Beast sunshell. I guess I should replace the reverse shell too because they get concave. . . .apparently. What make are the blues. The Raybestos Z Pack that Pete K suggested seem to get rave reviews everywhere. . . and they are only twenty bucks more generally...
How long did it take you to remove your tranny from the car?
I can do it in about 45 minutes.
The z-pack requires a later gm apply ring. The instructions in the kit provide the part number. If I was not sitting at o'Hare airport, I would look up the part number.
Lol
Pete, you sound like me. . . . .I always have the CF window open while I'm doing work too. I'm quite addicted to the site. Perhaps they should have a 12 step program for addicted CF members.....
Ummm, I'll wait till the 12th if you have the raybestos z pack and gm clip for a edcent price...
You may want to talk to this guy too. I just bought a kit from him and had it installed. He knows his ****.
http://www.700r4l60e.com/
It's a good idea to replace the reverse input drum if you have a lot of miles on the transmission or if you will be using a wider 2-4 band. Transtar sells a nice reverse input drum for around $65. Get the wider bushings for the reaction sun gear and the rear of the stator support.
Bruce
Bruce
