Looking for Tips on Mods.
Old Apr 3, 2008 | 11:51 PM
DOC152's Avatar
DOC152
Navigator
Default Looking for Tips on Mods.
Good day to everyone! I have a 96 LT1 Collector Edition 18,000 mi and with spring here I am looking for more hp and aggresive sound without blowing the wife out of the car going down the highway. I have already added (possibly foolishly) SLP air intake, Machined MAF and stock throttle body enlarged to 52mm with air foil. I am kind of new at this so its a learning process. What are some avenues I can take that will achieve my goals in the range of $2500 to spend? I do have a local shop willing to do a dyno tune once the mods have been installed. Any and all tips or recomendations are greatly appreciated. Thanks for your time and help in this.
Old Apr 4, 2008 | 01:06 AM
carriker's Avatar
carriker
Exhaust is a relatively cheap and easy mod. Long tube headers and catback exhaust or just headers and some highflow mufflers.
Want more? Go with a new cam and tune and some new rear end gears.
Headers + Gears + Cam + Tune = fast C4
Old Apr 4, 2008 | 06:19 AM
96 lt-4's Avatar
96 lt-4
New cam,springs,1.6 rockers,and dyno tune should take care of the hp.
For the sound I would consider some long tubes running into the factory catback or a corsa exhaust off your manifolds.Doing both would likely exceed your price goal unless you plan on doing the engine work yourself.
Old Apr 4, 2008 | 10:23 AM
rickneworleansla's Avatar
rickneworleansla
I would install LT's headers, a cam, and a tune, especially if you already have the 3.07 gear. If you have the 3.07 I would do a torque converter before new gears anyway. You could also go with N2O instead of the other stuff, gain 100+ hp, and have some $$ left over.
Old Apr 4, 2008 | 10:35 AM
StealthLT4's Avatar
StealthLT4
for $2500? Your exhaust is actually pretty free-flowing, so blowing $1,000 on a nice cat-back won't really net you any hp gain, just sound.
That being said, if I were you I'd focus on the exhaust first. Long-tube headers (LT for short), high-flow catalytic converters, and either an exhaust or replace your mufflers with straight pipes.
If you still have money left over (depends heavily on exhaust vs straight pipe), go for the GM Hot Cam kit and a dyno tune.
All that exhaust work might get you 20hp, but the main focus will be sound. It will be MEAN. Go to my PhotoBucket website if you want to see video clips of mine (LT4 with LT headers, cats, Corsa exhaust). Putting the cam in might get you another 30hp, depending on the tune.
Old Apr 4, 2008 | 10:48 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
LT headers can be loud. I am not a fan of LT headers on a street car. I would do the complete Hotcam kit with 1.6:1 roller rockers, springs, etc. Then you will need a good tune. The LT1 exhaust is pretty good.
Next I would look at gears. Once the cam is in you could go to a 3.45 rear set.
Old Apr 4, 2008 | 11:46 AM
rickneworleansla
Give some more info on your car. Auto or manual? Factory gear? Any other mods? Goals? Driving style? Daily driver, weekend racer, etc.. Future plans?
Old Apr 6, 2008 | 12:51 PM
DOC152's Avatar
DOC152
Navigator
The car is automatic with the 3.07 rear end. The car is a weekend car (<2000 mi. per year, garaged and stored winters). Once I start playing with it I would like to show it, but still take it on the road.
Old Apr 6, 2008 | 01:21 PM
BADDUCK's Avatar
BADDUCK
Three good mods
1) GM Hotcam Kit with cam, 1.6 RR's, springs, small parts = nice power and sound
2) Corsa Catback = Sound + low resonance
3) 3.45 Gears = SOTP stoplight speed
Old Apr 6, 2008 | 01:32 PM
bobmic93's Avatar
bobmic93
How about heads and cam. You gain 100 rwhp and loyed elliot has set ups for $1500. A grand left over for labor.
Old Apr 6, 2008 | 01:39 PM
DMcRacer's Avatar
DMcRacer
I just picked up my first Vette, 94 with a 6-speed. However, I do have alot of F-body experiance. I have 02 SS "cam only" car that runs 10.7 and I've owned a couple LT1 cars.
If the Vettes respond to mods like the F-bodys, I can assure you a stall converter will net you more gain than anything besides a power adder. I put a Vig 2800 in my sons 96 Formula and dropped the 1/8 mile ET from 9.07 to 8.60 with no other changes. And his car has 2:73 gears. If you do get a stall I would go with a Yank or Vigilante only. You'll be happy with either
Old Apr 7, 2008 | 02:21 AM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
You never said if your Collector Edition is an auto or a Six..I'm guessing an auto...
Old Apr 7, 2008 | 02:49 AM
ZD1's Avatar
ZD1
Yep, after all I've done I wish I wouldv'e just done full exhaust. If the car is an auto a good Tq mult (2.5) 2400 stall would be nice as well,
To Looking for Tips on Mods.
