90 with bad vibration
thanks
thanks
As for the vibration, how many miles on your car? How do you use it? Do any Autocross? Usually if the bearings are bad (front or back) there will be play in the wheel. Remember, there should be basically no movement when you grab the tire at 3 and 6 and try to move it back and forth. If there is, it's new bearing time.
Read this thread, it should help save some $$$.
http://forums.corvetteforum.com/show....php?t=1392417
Good Luck,
Randy
I replaced the rotors and still have the same vibration and brake pulsing. With the new front rotor on, I still get that "warped rotor sound" from the drivers front which I know that rotor is not warpped as it only has 2 miles on it now. When I grab the front tires at 3 and 9 and rock it I get no movement and a very little back and forth when grabbed at 12 and 6. The car has just over 100K miles on it. I just got the car and know nothing about its past but would be driving it normaly no autocross or anything like that.
So, clean the hub surface well and make sure there's nothing on the back of the new rotor. I use a 0.0001" resolution dial gauge to check the hub and rotor run out (axial - that is, parallel to the axis of rotation). At the perimeter of the rotor, you must get less than 0.004" axial movement but less than 0.001 movement is desirable and achievable. If you have more, check the run out (again axial) of the hub. The hub is smaller diameter than the rotor so it should have <0.003 or so run out. If the hub has excessive run out, replace it. If the hub is OK and the rotor is not, make sure the mating surfaces are clean. If they're spotless, replace the rotor or have it turned.
Really inexpensive (~$20) dial gauges are available from a some of the 'discount' tool stores and work quite well.
Good luck.
Measurements of runout didn't turn up anything obvious, so I ended up replacing a bunch of stuff that was suspect - multiple wheel balances, all new bearings & shocks as well as the initial R&R of pads/rotors. I finally gave in and had my new rotors turned, and although they measured good (except for one figure that was "close enough"), they both made a hellacious clatter on the lathe at Midas.
It wasn't until I went to NAPA for a second pair (the first were not NAPA) of front rotors that my problem was 100% solved. Live & learn.
This might not address the cruising vibration, so you may have other things going on as well.
I'd venture a guess that your wheel bearing would have to be pretty toasted to pulse during braking, but a bad bearing can give you a road vibration on the highway, too.
mypantera, I'm a couple exits down 295 from you. If you don't figure it out, feel free to drop me a message and I'll see if I can give you a hand if you'd like.
Runout will usually come along with slop or play in the steering. Loose wheel bearings up front do the same.
Vibrations like you are talking about come from halfshaft ujoints. My guess brake shudder and vibration is 2 problems.
Have the tires balanced on a Hunter GSP9700 road force balancer ( http://www.gsp9700.com/ look at there website) if the shake is comming from a tire and wheel that machine will show it in 2 minutes.
JS
