Are the LT1 tachs off?
Old Dec 12, 2001 | 01:11 AM
jay17's Avatar
jay17
Default Are the LT1 tachs off?
I got a program from Shark ssn591 (thanks) that shows rpms and mph at different tire sizes, gear ratios, and trans. It is showing 75mph@1768rpm for 2.59s. The tach in my car shows 1950-2000rpm@75mph :confused:
BTW, for 3.07s the program shows 75mph@2105rpm.
Old Dec 12, 2001 | 01:39 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Are the LT1 tachs off? (jay17)
Torque converter slippage tire sizes not exactly the same and other things can make the speed different.
Old Dec 12, 2001 | 01:48 AM
GlockLT4's Avatar
GlockLT4
Default Re: Are the LT1 tachs off? (93Polo)
All tachs are off in my opinion.. :yesnod:
Old Dec 12, 2001 | 02:37 AM
jay17's Avatar
jay17
You do have to enter tire size for it to work.
Old Dec 12, 2001 | 07:14 AM
RichS's Avatar
RichS
My 95 was off about 500 RPM. Not sure about the GS but it prolly is too.
Old Dec 12, 2001 | 08:08 PM
JasonL's Avatar
JasonL
Default Re: Are the LT1 tachs off? (RichS)
If you can read the tach signal on the PCM or coil directly, that will be a much better judge of how inaccurate your tach is. If you are using vehicle speed to calculate things, you've introduced the tire size variable. Keep in mind that different tire brands/models will vary a bit in actual size...tread depth makes a difference, etc etc etc.
Direct comparison between PCM and tach is the best way.
Old Dec 13, 2001 | 11:47 PM
R23HTC's Avatar
R23HTC
Default Re: Are the LT1 tachs off? (JasonL)
At idle on the dyno it reads 750rpm (like it's suppose too), but the tach reads 1000rpm. They were shifting at 5500rpm and the tach was almost to 6000rpm. :rolleyes:
Old Dec 14, 2001 | 02:54 AM
jay17's Avatar
jay17
Default Re: Are the LT1 tachs off? (R94 LT 1)
My car shows its shifting at 6000rpm. I'm not sure what autos shift at but I don't think it's 6000rpm :crazy:
Old Dec 14, 2001 | 04:05 AM
GlockLT4's Avatar
GlockLT4
I'd much rather it be reading high than low though! (for a standard ... auto doesn't have to worry about it except when manually shifting)
Old Dec 14, 2001 | 02:02 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
me too, confirmed on the dyno :mad
Old Dec 14, 2001 | 08:29 PM
silver & red CE's Avatar
silver & red CE
The error is an offset, not a percentage error. If your tach is off by 500 RPM at 2000rpm, it'll be off by 500 RPM at 5500 RPM. The cause of this error is that GM has a big problem with getting the needle on correctly. It's not easy with the present system. The Flint plant looked at fixing the problem in the early 90's, but it was decided that nobody really cares. Would have cost ~$0.50 per car to fix this (another great decision by GM managment).
Eric
Old Dec 14, 2001 | 09:56 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
PURE JUNK. :mad
To Are the LT1 tachs off?
