C5 z06 wheels with 38mm offset
Old Apr 6, 2008 | 02:25 PM
chevydave53's Avatar
chevydave53
Cruising
Default C5 z06 wheels with 38mm offset
Does anyone know where i could find a set of C5 z06 wheels with the 38mm offset for my 87? All i can seem to find is ones with the 56mm offset. Any help would be appreciated.
Old Apr 6, 2008 | 06:24 PM
85blkrose's Avatar
85blkrose
not gonna happen. need to use wheel adapters to use the zo6 wheels
Old Apr 6, 2008 | 06:26 PM
c4cruiser's Avatar
c4cruiser
Don't think anyone makes them. Would be great to have C5/Z06 wheels with the 84-87 offset, but one of the companies would have to step forward and bring some to market. Could be expensive to do if the sales are not high from the git-go.
Old Apr 6, 2008 | 07:01 PM
chevydave53
Cruising
I had a feeling that this was what you guys were going to tell me. Anyone ever seen them made?
Old Apr 6, 2008 | 07:05 PM
85blkrose's Avatar
85blkrose
i have been lookin for two months now. i have seen offsets in the lower 50's but none lower than that. i have also seen you need to use a 1" spacer because the required 3/4" spacer will let the studs protrude past the spacer and hold the wheel out from the mounting surface(for the zo6 wheel at least)
Old Apr 6, 2008 | 09:11 PM
chevydave53
Cruising
Yeah i've heard that about the studs sticking out too far on the 3/4 inch spacers. My understanding is that it depends on the wheel that you buy though. Some have areas in the back removed so the tips of the studs dont hit with the 3/4" if i'm not mistaken.
Old Apr 6, 2008 | 09:29 PM
dclafleur's Avatar
dclafleur
Have you sent a message to TomLzzz with Tomzwheels? He's a vendor and might be able to help you out.
Old Apr 6, 2008 | 10:28 PM
bjjenks's Avatar
bjjenks
Cruising
I have a set of Camero wheels with the same offset - I tried one on the rear of my 84 and it looks like a 1/2" may be enough. I would rather use this simple spacer rather than the 1 inch adaptors even if I have to have longer wheel studs. Has anyone tried these?
Thanks,
Bill
Old Apr 6, 2008 | 11:16 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Dead Wrong Answer: TomZWheels, I have the C5Z06 17" all 4 and with correct offset...
Old Apr 7, 2008 | 01:05 AM
KENS80V's Avatar
KENS80V
I believe the only way to get that look is to buy the Z06 "Motorsport" wheels with the fake rivets as mentioned above. They are available from several vendors in different finishes.
Old Apr 7, 2008 | 01:09 AM
Demonic85's Avatar
Demonic85
Maybe they made them at one time, but they dont have them available now. I already asked Tom about it.
Old Apr 7, 2008 | 01:56 AM
KENS80V's Avatar
KENS80V
www.lakeshorewheelandtire.com still lists the "Motorsport" Z06 style wheels with the 38mm offset for sale.
Old Apr 7, 2008 | 02:03 AM
Demonic85's Avatar
Demonic85
18x9.5 inch , 5x4.75 inch 40mm
Chrome Wheels
# Fits 1984-1987 Chevy Corvette
# $869/set
# Brand New Reproduction C6-ZO6 Style Wheels
# Center caps are included.
17x9.5 inch , 5x4.75 inch 38mm
Chrome Wheels
# $829/set
# Brand New Reproduction C6 Style Wheels
Old Apr 7, 2008 | 09:35 AM
c4cruiser's Avatar
c4cruiser
When you mount late C4 wheels on the early cars, the adapters with the acorn-style nuts do protrude past the adapter face. But OEM C4 wheels have recesses on the mounting flange between the holes so that the acorn nuts simply fit into those recesses.
If OEM C5 wheels (thin spokes or Z06) have a flat mounting flange with no recesses, then you have to go to thicker adapters or use different nuts on the adapters. The stud length on the 3/4" adapters could be an issue too.
Going to a 1" adapter should not be a problem unless you go to oversize tires. Just check carefully for any rubbing at the frame rail or edges of the fenderwells.
Old Apr 7, 2008 | 09:39 AM
TomLzzz's Avatar
0TomLzzz
Former Vendor
As far as I know there is not anyone making a C5 Z06 wheel in the correct offset. I think there are some companies making a C5 Z06 Motorsport but ewe do not have them. They do make the C6 Z06 with a 40m offset that will work and we also have the ZR1 and Torq Thrust II's that will work.
One other benefit for the adaptor versus the spacers is that the adaptor is much stronger than the spacers. If you are running a lot of HP/TQ there is a lot of strain on anytrhing above a 1/4 or 5/16 spacer.
Tom
1-866-939-1030
Old Apr 8, 2008 | 10:25 PM
chevydave53
Cruising
thanks guys... i sent tom a pm
To C5 z06 wheels with 38mm offset
