C6 Conversion Questions
Old Apr 7, 2008 | 01:17 PM
Danspeed1's Avatar
Danspeed1
Default C6 Conversion Questions
Hey guys,
Couple of quick questions
1. I got everything I need for my C6 Brake Upgrade. The last thing I am missing is the "bias springs" for the master cylinder. I was told to go to Doug Rippie Motorsports to pick one up. I just wanted to find out more about the spring. For example, what type of proportioning changes does it make to the front and back as far as braking. I just wanted to also find out if there are any better options.
2. What do you guys think about Line Lock/Roll Control. I am thinking about installing it when I put the setup in the car to make it easier to heat the tires when I go to the track and do the occassional, massive burnout on the street. What manufacturer should I go with, or does it not matter?
Dan
Old Apr 8, 2008 | 01:22 AM
Danspeed1's Avatar
Danspeed1
ttt
