The carb Convert from TPI
Old Apr 7, 2008 | 07:20 PM
shamdave's Avatar
shamdave
Default The carb Convert from TPI
Ok i have had it with MAF,TPS,IAC and all the other sensors! Im going old school ECM Be damned!
Has any one done this?
I am going with duel 4bbl Holly 600 CFM on an ellerbrock intake
I also know i have to change the Dist (any suggestions)
Can i eliminate the ECM after the conversion?
Thoughts?
Oh BTW 1985 Performance Chip,160degree thermo. Other than that bone stock 91k miles
Old Apr 8, 2008 | 07:35 PM
xrcrx's Avatar
xrcrx
The ECM stays in place. The HVAC system uses it. Just tuck the unused harness out of the way. You will need a vacuum advance distributor, intake,carb, fpr for fi to carb with bypass,and a kit to lock up your torque converter since the computer will no longer be able to do it.
Old Apr 18, 2008 | 09:16 PM
shamdave's Avatar
shamdave
How in the world do ou lock up the torque converter? i am a little lost on this one
Old Apr 18, 2008 | 10:00 PM
Syclone354's Avatar
Syclone354
either a toggle switch or a controller. I think b&m makes one that is basically a speed switch that you can set for whatever mph you want and it locks the converter at that speed.
Old Apr 30, 2008 | 07:12 PM
shamdave's Avatar
shamdave
Cool are they hard to install?
Old Apr 30, 2008 | 09:48 PM
xrcrx's Avatar
xrcrx
I used a TCI kit, just under 100.00. It operates off vacuum and a switch. Not too hard to install. Gotta drop the pan.
To The carb Convert from TPI
