'91 changing rear diff, no gasket??
Old Apr 7, 2008 | 07:56 PM
kennedys22's Avatar
kennedys22
Default '91 changing rear diff, no gasket??
I want to change my rear diff oil on my '91, 71K miles. I was going to take the cover off to clean the area. The Chevy dealer said there was no gasket replacement. Sold me a ED? silicone style sealer. I am going to use GM diff fluid and one posi additive.
Should I remove the cover plate or just pump out what's in there and replace it? No gasket - does this sound right? Any tips from previous experience is appreciated!
Old Apr 7, 2008 | 08:03 PM
wayne lowry's Avatar
wayne lowry
Correct, there is not a gasket from the factory. If you have something to pump the old stuff out it would be a helluvalot easier.
Old Apr 7, 2008 | 08:05 PM
CFI-EFI's Avatar
CFI-EFI
No gasket is correct. If that makes you nervous, you could always make your own. Most people in the know, add two of the 4 ounce bottles of the posi additive.
RACE ON!!!
Old Apr 7, 2008 | 08:08 PM
kennedys22's Avatar
kennedys22
I asked the guy at the counter about two bottles (thought I had seen this in another post). He talked me out of it. Hopefully I won't have any noise - I suppose I could get some more in later.
I'll go at it - no gasket and all. Thanks to you both!
Old Apr 7, 2008 | 10:26 PM
VinceAD's Avatar
VinceAD
I suctioned the old fluid out with a pump I got at Advanced Auto then pumped in the new fluid with the LSD fluid.
To '91 changing rear diff, no gasket??
