1987 L98 Spark plugs cross reference chart?
Old Apr 8, 2008 | 03:26 PM
Calderone's Avatar
Calderone
Default 1987 L98 Spark plugs cross reference chart?
Hi,its been really hard to find the FR5LS Spark plugs and Summit got them on ebay but i ask and their answers to my questions are just automated,they answers what they want to answer,not my actual questions.-
Im in need for a brand new set of spark plugs for my L98 (with alum heads ) and i need a cross reference chart....
whats the FR5LS (Which i was told are the correct plugs) on NGK or other brands ? What's your favorite ?
Please help !!!!
thanks !
ps : my mods : Hypereuctectic flat top pistons,ZZ4 Camshaft...just for the record i dont know if i have to use another kind of spark plug since i upgraded the compression ratio with the new pistons
Old Apr 8, 2008 | 06:28 PM
Calderone's Avatar
Calderone
How about 2 sets of vintage FR3LS
CLICK HERE
Old Apr 8, 2008 | 07:13 PM
rick lambert's Avatar
rick lambert
Or just go to the ACDelco site on line.......you'll get exactly what you need.....waiting for a call or I'd go out and look at mine.
Old Apr 9, 2008 | 10:29 AM
Calderone's Avatar
Calderone
i couldnt find any info,they look for part # and i guess FR5LS or FR3LS are not part numbers ...ok ok
Which are the correct spark plugs for my L98 w/alum heads ?
AC DELCO : ? ____________
NGK : ? ____________
MOTORCRAFT : ? ____________
AUTOLITE : ? ____________
Other brand ? ____________
Please someone help me fill the blanks,im getting close to start the car for the first time and i dont have the time to buy them overseas (Im in Chile) because it will take at least 2 weeks to get here and i need to start it before April 20th H E L P !!!!!!
Old Apr 9, 2008 | 10:41 AM
Calderone's Avatar
Calderone
Ok i just found out this from BOSCH and :
And another chart here :
Which should i believe ...use ...trust....which one its better ???
But look at the Champion...they show different spark plugs !
i want the best of my engine,and i dont want to ruin it using inadequate spark plugs!
Old Apr 9, 2008 | 10:53 AM
bczee's Avatar
bczee
just got to the CSKAuto.com, Autozone.com or any of the online parts stors...and pull up your application for your year and engine.. that should list almost all of the plugs to fit your 87/L98..
Try this for a starter..
http://www.partsamerica.com/ProductL...pe=960&PTSet=A
or
http://www.autozone.com/N,16200033/N...eResultSet.htm
Old Apr 9, 2008 | 11:10 AM
Calderone's Avatar
Calderone
thanks i found out the 41-629 on the bay
its the same of FR3LS ?
damn ,i have to buy all overseas for me ...
no one have vette stuff here in s.a.!
Old Apr 9, 2008 | 12:18 PM
Calderone's Avatar
Calderone
i just got my set of 41-629's from the bay !
Browsing thru AC-Delco's site i found this
I purchased 41-629,what's the difference with rapidfire or platinum plugs ?
Will my engine be OK with the 41-629's ? it does not say ALUM Heads over them !!!!
Old Apr 9, 2008 | 12:50 PM
Demonic85's Avatar
Demonic85
You can tell the difference between a spark plug for an aluminum head and a cast iron head by comparing the two plugs. The cast iron will have a short area of thread. The aluminum plug will have a longer threaded area and they usually have a washer on the bottom of the threaded area. Here are 2 examples.
Cast Iron heads
Aluminum heads
Old Apr 9, 2008 | 12:51 PM
Calderone's Avatar
Calderone
Yes, i know but does the 41-629 Its OK for my heads ?
thanks
it looks OK from what i see...
i got confused because of the application chart on post #8
http://forums.corvetteforum.com/show...16&postcount=8
But they seem OK ...what you think ?
To 1987 L98 Spark plugs cross reference chart?
