3rd Brake Light Issue
Old Apr 8, 2008 | 06:19 PM
F0RMULA's Avatar
F0RMULA
Default 3rd Brake Light Issue
Need to get my 87 inspected this week and the 3rd brake light isnt working. Replaced the bulbs and still nothing. Is there any special grounding or anything needed? Any thoughts?
Old Apr 8, 2008 | 06:26 PM
69mako's Avatar
69mako
Look at the connections for any signs of a broken wire or a rusty socket, check the fuse, check the ground, put a volt meter on it, check the volts and look for a short.
Old Apr 8, 2008 | 06:48 PM
c4cruiser's Avatar
c4cruiser
The 3rd brake light has a separate wire coming off the brake light switch. It's possible that the switch may not be allowing curent through the wire or the wire is loose.
The brake light switch sits above the brake pedal. The 3rd brake light wire is light blue and is in cavity C of the connector. Depressing the brake sends voltage to the 3rd brake light. Check for 12v at the wire going into the lamp housing.
If a separate ground wire at the housing causes the light to come on, the ground wire is bad. You can also check for continuity between the light blue wire at the brake light switch and the lamp housing and the same for the ground wire.
Also check the ground wires at the lamp and at the ground connection for corrosion or loose connections. For coupes, the ground wires will be at the right hand side of the cargo compartment, rear of wheelhouse. The ground wire post should be below the right hand shoulder belt attaching point.
Old Apr 8, 2008 | 07:55 PM
cmontel727's Avatar
cmontel727
Another thought is to take the light physically off the car and check the wires. Some body shops like to cut the wires for the third light to remove it for painting. They will then forget to splice them back together when they put the light back on the car. Ask me how I know
Old Apr 8, 2008 | 08:00 PM
JackDidley's Avatar
JackDidley
Switch at the brake pedal. About $10. It can fool you and show 12V at the lights, but not be strong enough to turn them on.
Old Apr 8, 2008 | 09:53 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Haha, been there. Lazy **** shops!
Old Apr 8, 2008 | 10:21 PM
SS409 425HP's Avatar
SS409 425HP
Exactly what happened on my '87. I had about 11.5 volts at the light socket but the bulbs wouldn't light at all. It was the brake light switch at the pedal.
Old Apr 11, 2008 | 05:32 PM
69mako's Avatar
69mako
Update please
What was the problem slim?
To 3rd Brake Light Issue
