Instrument Cluster swap
Old Apr 8, 2008 | 07:32 PM
wayupnorth's Avatar
wayupnorth
Default Instrument Cluster swap
Will a 1993 Instrument Cluster work in a 1991 L98 C4?
Old Apr 8, 2008 | 07:53 PM
WVZR-1's Avatar
WVZR-1
Are you trying to exchange the cluster complete or just swap some components?
Old Apr 8, 2008 | 07:59 PM
wayupnorth's Avatar
wayupnorth
Whole unit, my tach is out and now my LCD is extremely hard to read in bright light
Old Apr 8, 2008 | 08:09 PM
WVZR-1's Avatar
WVZR-1
Do you have both clusters now? If you had both clusters I think I'd transfer the "circuit board" from the '93 and see if it corrects the tach. I'm assuming your tach is reading something substantially higher than actual.
If your tach isn't working at all you could just swap the tach module also I believe. I can't answer the question regarding the display!
To Instrument Cluster swap
