Lowering the rear on a C4?
Old Dec 12, 2001 | 03:21 PM
t.renz791's Avatar
t.renz791
Default Lowering the rear on a C4?
My father has a 91 that sits like an elephent on rollerskates in the rear. Is there a way to drop the rear of this thing maybe 3/4 to an inch without changing the spring?
Thanks for any help!! :flag
Old Dec 12, 2001 | 03:33 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Lowering the rear on a C4? (t.renz791)
Yes, costs $20 and you can get it from Ecklers, zip, MAD, wherever. Its just two long bolts. Installs easily. You will need to have the car realigned when you're done. :cheers:
Old Dec 12, 2001 | 03:34 PM
92TripleBlack
Default Re: Lowering the rear on a C4? (92TripleBlack)
BTW, where's New Yak? :rolleyes:
Old Dec 12, 2001 | 03:37 PM
94Controller's Avatar
94Controller
I take it you can't get the same bolts from just anywhere (strength, threads per inch, etc.). Sounds like quite a mark-up for 2 bolts. :confused:
Old Dec 12, 2001 | 04:52 PM
t.renz791's Avatar
t.renz791
People hassle me for having a "thick Buffalo accent."
Sorry if my attemt at humor has upset you in any way............oh wait, no I'm not! loosen up!
:yesnod:
To the others that provided usefull info. thanks much!
If the bolts that get replaced are simply shorter than the stock ones, couldn't we just cut them? I imagine if the bolts see a lot of stress, putting them through a heat cycle and cutting them most likey wouldn't be the way to go to save 20 lousy dollars.
Thanks again,
Tim :cheers:
Old Dec 12, 2001 | 05:36 PM
JoBy's Avatar
JoBy
You use longer bolts to lower the rear.
Brian Madderom's Avatar
Brian Madderom
The bolts in question are actually longer (10") to drop the rear and are usually grade-8 hardened. :cheers:
Old Dec 12, 2001 | 09:11 PM
pablocruise's Avatar
pablocruise
Default Re: Lowering the rear on a C4? (Brian Madderom)
And use a cotter pin to secure the nut too! Stock bolts are 9". So new bolt as mentioned above is 10+". :cheers:
Old Dec 12, 2001 | 10:13 PM
Hammer's Avatar
Hammer
Default Re: Lowering the rear on a C4? (89 Paul in cal)
Used the bolts
Before: Looks like a 4x4
After: Looks like a Vette
BBA's Avatar
BBA
where's New Yak?
wher e paaks da ca'ah
Old Dec 12, 2001 | 11:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The bolts are longer and at least grade 8 in hardness. Some guys do the homework, search out a hardware that has em and spend about $5 or so. I prefered to just open the box from MAD, take my two jacks and a tape measure out to my Vette and 1/2 hr later it was 1 1/4" lower at the rear wheels.
First I measured the ride height at the center of the wheel wells on all 4 wheels. Then I replaced the two rear bolts (the chassis actually hands from the rear spring via these two bolts) and set the ride height the same as the front, on each side.
It looks much better, feels like a different car and handles much better; well worth the $20 or so.
NOTE: If you intend to drive the Vette much over 100mph you sould retain some forward rake to maintain some down force to prevent lifting at high speeds.
Old Dec 13, 2001 | 01:40 AM
t.renz791's Avatar
t.renz791
Default Re: Lowering the rear on a C4? (65Z01)
Once again, thanks guys. This board is a thing of beauty. I look foward to the day when owning a Corvette is within my grasp! :cheers:
To Lowering the rear on a C4?
By Michael S. Palmer | 2026-06-03 11:00:24
