Massive air flow system????
Old Dec 12, 2001 | 04:52 PM
Redding's Avatar
Redding
Default Massive air flow system????
Check engine light just started coming on and I am told 3 codes are coming up. They used the term “massive air flow system”
I am new to this, how bad is this?
1987 with 42,000 miles
Old Dec 12, 2001 | 04:56 PM
vader86's Avatar
vader86
Default Re: Massive air flow system???? (Redding)
you need to tell us which codes are coming up, by the number. Youre probably getting a code for just a bad Mass Air Flow sensor, $250-400? for a stock new one, or you could be gettin a code for the Relays which you can get for $15-20 for both. If you have to replace the sensor then go ahead and get the relays because theyre probably bad too, MAF and relays cause each other to go bad.
[Modified by vader86, 8:57 PM 12/12/2001]
Old Dec 12, 2001 | 05:31 PM
Redding's Avatar
Redding
Default Re: Massive air flow system???? (vader86)
I will get the codes.
Old Dec 12, 2001 | 06:17 PM
Redding's Avatar
Redding
The codes are 34, 36 do not know the third one.
Old Dec 12, 2001 | 09:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
34= MAF reading too low
36=burn-off relay problem
Fix the burn-off relay problem first. It may fix the MAF low readings.
Replace the MAF burn-off relay remove the bellows from the front of the MAF, with a mirror verify that the sensor wire glows red for 2 sec after turning off the motor.
To Massive air flow system????
