86 precat proplem
Old Apr 9, 2008 | 07:41 PM
04bosco's Avatar
04bosco
Default 86 precat proplem
I had my pre-cats cut off last week, just looked under the car and i see a piece of tubing just hanging there, can anyone tell me what this might be and what should be done with it.thanks
Old Apr 9, 2008 | 07:53 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Sounds like the line from the AIR pump that goes to the main cat was cut. Is it metal or rubber tubing?
Old Apr 9, 2008 | 07:54 PM
redrose's Avatar
redrose
if it's on the passenger side, chrome, abt 1/2'' dia, it's the air feed to the main cat...should not have been cut by your ''pre-cat skinners''...may be an emissions inspection problem...your ecm won't notice...should be repaired/continuous.
Old Apr 9, 2008 | 08:00 PM
04bosco's Avatar
04bosco
It is metal tubing on the passenger side about 1/2 inch what should i do with it precats where removed along with main cat
Old Apr 9, 2008 | 08:04 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Strap it to the exhaust or remove the AIR system
Old Apr 9, 2008 | 09:39 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Mine is cut and strapped to the exhaust. The end that is cut was just left open. It doesn't seem to cause any problems. No cat at all. Just straight through pipes to the mufflers. Classic plates so no emissions needed.
To 86 precat proplem
