SMOKE Geeze
Old Apr 9, 2008 | 08:11 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default SMOKE Geeze
I went to the store and came out to a little condensation by the defrost vent. So I turned on the defroster and Smoke started pouring out of the vents. I guess I know why the heater core was bypassed when I got it now. I have been driving it for weeks since I hooked it back up with no issues. I turned on the vents and the smoke stopped. I tried it in my driveway after getting home and it was OK at first but then the windows started fogging but verylittle smoke. I am wondering if it is worth it to toss some Bars Stop Leak in (GM uses it)? I know the final solution is a new core but I do not want to pull the dash out yet. I know I could rebypass it but I need defrost sometimes. Has anyone had sucess with the stop leak for any length of time?
Old Apr 9, 2008 | 08:24 PM
Redeasysport
I have read several good write ups on doing the core but they were mid 80's cars. Any tips on a 93 I should know before doing this?
Old Apr 9, 2008 | 08:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
JIMO, I'd NEVER put stop-leak into my cooling system.
Two summers ago I replaced the heater core in my "new" '88 IROC-Z; though it was the 1st core I'd ever done it went very smoothly with the FSM as my guide.
Old Apr 9, 2008 | 08:58 PM
Redeasysport
I am just wondering if my 93 is as easy as L98 cars. The FSM directions have me disconnecting just about every wire and hose in the dash to do it but some of the write ups I have read do not mention any of that and make it sound sorta straight forward.Is this is a case to ignore the FSM and can I follow the write ups from the late 80's cars?
Old Apr 9, 2008 | 10:00 PM
65Z01's Avatar
65Z01
I wouldn't discount the FSM without actually seeing the setup in detail.
I guess you could start into it and go with the best method; in any case you will see what needs to be disconnected as you proceed.
I suspect most of the project is about getting the front off the plenum so you can access the heater core.
Old Apr 9, 2008 | 11:12 PM
Redeasysport
What I am trying to avoid is pulling the dash pad. I know they never go back exactly right and end up rattling or creaking. I haven't looked at it yet but I assume the biggest difference between the right ups I have read is the glove box. I wonder if that comes out without pulling the dash if it does I can see it being a little easier.
Old Apr 10, 2008 | 12:11 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Do a search on the "fast guy method", but from reading it, it is not an easy job, and you have an air bag to contend with.
Good luck
Old Apr 10, 2008 | 12:16 AM
Redeasysport
I have it and several other versions bookmarked. All of them are for earlier C4's I am looking for input from someone who has done a 93 and up core with one of those methods.
Old Apr 10, 2008 | 02:26 AM
65Z01's Avatar
65Z01
You might IM MrMojo, I think he's done a heater core but not sure if it was on his '93???
Old Apr 10, 2008 | 02:49 AM
RandyJ75's Avatar
RandyJ75
Do a search on Jet Jock, I think his car was a '93, and he did a big write up on it.
Old Apr 10, 2008 | 09:50 AM
Redeasysport
Nothing on JetJock except a few posts. I remember him . Bypassed it for now while I figure out the best way to approach it.Procrastinating actually I am not looking forward to this..
Still looking for someone with a 93 to chime in on this though. I will PM Mojo.
Old Apr 10, 2008 | 10:57 AM
newbecorvetteguy's Avatar
newbecorvetteguy
I'd try the stop leak. Been using it myself since the 70's. If it doesn't work, your out a couple bucks.
The heater core started leaking a little in our Dodge Durango last year. The fix is to evacuate the ac and tare dash apart to the firewall. Before tackling this myself which I'm not in the mood to do or pay someone $600 to replace a $40 part, I tried stop leak. After a few days the steam and coolant smell went away. Been good since. I do carry a splice and a few tools on long trips so I can by pass it just in case it really fails a long way from home. Stop leak works fine for minor leaks. Won't do a thing if somethings really wrong though.
Old Apr 10, 2008 | 02:52 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Look for jetjock93 or jetjockey93, he and I used to converse all the time. He is now in the c5 section, think he is jetjockey. Do an archive search for my id and pke, he helped me diagnose my pke problem.
Old Apr 10, 2008 | 03:12 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I was wrong, his id is - 93jetjockey
To SMOKE Geeze
