1990 Header selection and install...looking for advice.
Hi,
I want to install headers on my 1990 auto. Basically a stock engine at this point. I am planning on doing the install myself. Couple of questions for you...
1. Which header kits would be the easiest install? In otherwords, I do not want to make a lot of modifications, other than installing the headers themselves. Also, I do not want to eliminate any emissions components. Needs to be street legal in CT (must pass emissions).
2. How much will I need to jack the car? I am a big guy. Anyone have any tips on this?
Any insight you can provide will be helpful. Thanks!
If the car is stock, I would use Hedmans, they are 1 5/8in primaries. Get a pair of bullet cats and you can use your stock exhaust from the cats back(did this w/my lt1, think you can w/l98).
I used a floor jack and jack stands, I am a pretty big guy also. It is going to be tight; but is not to tight. I lifted the car as high as the floor jack would go, about 14" and then put the stands in, the only trick was getting the headers underneath and up into the bay. Take off the valve covers, it will make getting to the back bolts easier.
From the HEDMAN site (scroll down to the Corvette listings), it appears the 68487 is the best choice for the 1990. If you click on the part number, among other things it says, "4. Includes parts necessary to retain emission devices. (50 State)". It surprises me that this might not include an O2 bung. Since the question has been raised, I'd check with Hedman to confirm.
I'll be surprised if you will see much gain on a near stock car, if retaining the main cat and the rest of the stock L98 exhaust. Maybe 5-10 HP. TPIS sound to me like the easiest to install and you can re-use the stock bolts which is nice.
Note: The Pre-cats are typically eliminated with a header installation, so you won't be retaining all emissions devices.
You may want to consider a dual/x-pipe/bullet cat arrangement from someone like melrose or stainless works. Of course, this increases the cost considerably.
The easiest way to go is shorty headers, bolts right up to your stock exhaust. The only downside is that you wont gain as much power like you would with long tubes.
RACE ON!!!
You got me all hot 'n bothered with that 50 state thing.........until I opened the link & saw they disclaimed California
RACE ON!!!
That is the headers I have and trust me, I spent $40 putting o2 sensors in them. They have air fittings and that is it, the o2 is not an emissions device, as I understand them to be a sensor.
But for $300 shipped and $40 to put in the o2's, I am not complaining.
Sorry about that. All I did was cut and paste the footnote. I didn't go hunting for details. If they don't consider their home state as one the the "50", I wonder what they think number 50, is?
What about the EGR tube for the L98? They have a part number that claims DOESN'T have it. Since it says "Includes parts necessary to retain emission devices." it ought to be there. Not having an O2 bung is like not fitting with power steering, since ALL C4s have both as standard equipment. I think whether you call it smog equipment or a sensor, the headers ought to accommodate it. That's just MY opinion.
