Z51 Shocks
Old Apr 11, 2008 | 01:33 AM
rgdixon4546's Avatar
rgdixon4546
Default Z51 Shocks
Does anyone have information on shocks for Z51 suspension to include part number and any experience they have with them?
I was told the Z51 shocks would work on my 1995 and are amazing and decent price.
I am assuming they are Bilsteins?
Old Apr 11, 2008 | 02:19 AM
racebum's Avatar
racebum
I have used the shock you speak of. They aren't bad, they are actually valved light in my opinion for the early z51 springs. since the 95 is softer than the 90 z51 i tried them on it would probably be a great match. I just did a google search and found a set new for $289 on this link corvettetraderonline For the price the only shock that is competitive is tokico. Shocks, like everything else get better with cash. If you really want to skimp you can get KYB's, spend a little more and you can get either of the two i mentioned, spend more yet and you can get the wonderful Koni sports which are better but might be a little tight for the more lax 1995 z51 spring rates.
Old Apr 11, 2008 | 04:32 PM
jrp's Avatar
jrp
Part numbers can be looked up on Bilstein's website: link
They refer to Z51 shocks as "Sport" and base shocks as "Heavy Duty".
Old Apr 11, 2008 | 05:39 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
autopartswarehouse
Old Apr 12, 2008 | 01:08 PM
rgdixon4546
Default Zo7
Very helpful! Thank you! My 1995 has springs from 1995 ZO7 package. Does that change your mind any?
Old Apr 12, 2008 | 01:33 PM
BADDUCK's Avatar
BADDUCK
Not unless you plan to Auto-X. HD's are best for your Application IMO.
Old Apr 12, 2008 | 05:33 PM
rgdixon4546
Default Shocks for 1995 with ZO7 Suspension
Nope...not taking to track until I can afford repairs again...single income family for awhile...just good performance shock for cruising. I took the extremes off and put on old FX3's...they are on last leg and to expensive to replace. My actuator gears are chewed up anyhow...not worth money to replace.
Big ten four Badduck..so you think the Sport would be to rough with the ZO7 supsension and the HD's would work better?
Thanks for the links racebum and jrp. I am going to assume the shocks listed on corvettertraderonline are different and not as good as the ones listed on bilstein website?? The trader has whole set of 4 listed for 289.99 and doesn't list and option and bilstein website sells both sport and hd models for $121.00 a piece and shows at least two options (Z51 and Convertible)?
bilstein.
Old Apr 12, 2008 | 05:50 PM
rfn026's Avatar
rfn026
I'm a big believer in rebuilding your Bilsteins. You tell them how you drive and they'll do a custom set for your car. It's better than any off the shelf shock and a lot cheaper.
You can use the Bilstein link.
Richard Newton
Old Apr 12, 2008 | 11:31 PM
racebum's Avatar
racebum
listen to that guy above me, i know bilstein use to do fx3 custom valves for a little more. at least get prices before you make a choice. as far as the link i posted, i believe they are z51s but call and ask. many of the online retailers will sell under retail. the bilstein z51s i use to have i paid just under 300 shipped for. i sold them a month later as they were too lose for my tastes. much happier with the konis, however, you might not be. i really wish you could go for rides on different shocks before you buy them. in my eyes the stock z51 shocks are lose, others will disagree, that's why it would be nice for you to feel them. the only problem with soft shocks on z07 springs is if they are so soft you get bounce and the car gives you the boat feeling when you drive quickly. i can't personally comment on anything other than the stock bilstein z51s and the koni sports, they are the only ones i have tried on a c4.
Old Apr 13, 2008 | 01:01 AM
rgdixon4546
Default Shocks
Racebum, I think I know exactly what you mean when you say "boat feeling" and definitely what I want to avoid. This is same feel I get now with the FX3's...take a long turn at fast speed and get wheel hop...etc. Just not sure if it because FX3's are old and wore out and/or just not good match with ZO7 springs...etc so afraid to rebuild FX3'2 only to get same ride plus having them rebuilt would be I think waste since I dont plan on replacing the expensive actuators that fit on top of them that control dampener to 3 ride settings from inside control. All four of the gears are chewed up like most (plastic gears on metal doesn't last long).
I had Bilstein Extremes on before...they were a dream for handling, but man you paid for it...no give...very rough ride. So I guess I am looking for something between shape my FX3's are in and Extremes.
Is there only one Koni Sport for C4? Are the Z51 springs the same as springs on what is referred to as ZO7 suspension?
Badduck, would you have happened to drove on the HD's with ZO7 springs? If not what experience have you had with the HD's?
Old Apr 13, 2008 | 07:10 AM
Can86Z51's Avatar
Can86Z51
I did an application search on this Bilstein site for my Late 86 Coupe(Z51) and they listed their Z51/Sport shocks ONLY for the Fronts - it listed the rear shocks as the HD's? As far as I know, original early C4's with Z51 option need Sport Bilsteins both Front and Rear??
Old Apr 13, 2008 | 07:34 AM
BADDUCK's Avatar
BADDUCK
My experience is with Z51's on a Z51. That's why I say don't get them for cruising, get HD's. Go to corvettecentral
Old Apr 13, 2008 | 11:42 AM
rgdixon4546
Default FX3 Settings
Would you happen to know what 3 settings on FX3's are? Since gears are stripped on all mine I wonder if there is that big a difference between the hardest and softest settings. If I spend all that money repairng FX3 system I want lot of benefit. I'm just curious if I may be able to get the HD ride out of one of the thre FX3 settings??
Old Apr 13, 2008 | 12:01 PM
jrp's Avatar
jrp
I don't know enough to be helpful here. Maybe confirm by looking up the Delco part numbers & seeing what all the aftermarket vendors list.
Old Apr 13, 2008 | 01:09 PM
jrp's Avatar
jrp
Generally yes, as far as intent, but even Z51 changed from year to year:
Your Z07 springs are a good bit more stiff than the '96 Z51, but not as much so as the earlier Z51.
I have Z51 shocks now and it's just the feel I like even for cruising. My springs are the soft base ones, though, so YMMV. The car was more floaty than my daily driver Altima before the swap.
Old Apr 13, 2008 | 02:00 PM
racebum's Avatar
racebum
I wonder what calling bilstein and saying " man i love the feel of the extremes in a corner but they are a little much for my tastes crusing, what can you guys do to keep some of that 'in-control' feeling without killing me? " Also, from what you have said you might enjoy the Koni's set up soft, remember, they are adjustable. The Tire Rack also has pages of customer comments on this shock http://www.tirerack.com/suspension/s...ck&group=Sport
Old Apr 14, 2008 | 10:37 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Please no links to non-supporting vendors or other non IB vette site............they are da rules.
To Z51 Shocks
Old Apr 14, 2008 | 02:47 PM
racebum's Avatar
racebum
sorry about that
Old Apr 14, 2008 | 04:24 PM
rfn026's Avatar
rfn026
If you're serious about your FX3 package get a different controller from Bilstein. The way the FX3 was set up originally it was almost a useless toy. I even went to far as to suggest the switch wasn't really connected to anything - it was just there to make people think they were doing something.
You can get a really good FX3 suspension if you change the controller and have the original shocks rebuilt. I get into all of this in my C4 book so I won't bore you here.
I've also got charts of several diffferent controllers in the book. If you really want a stiff ride see if you can find an AA208 controller. That was commonly known as the autocross controller in it's day.
Richard Newton
101 Projects for Your Corvette 1984-1996
Ultimate Garage Handbook
Old Apr 15, 2008 | 01:21 AM
DREGSZ's Avatar
DREGSZ
Richard Newton
Amen,
Call Jack at Bilstien, He's forgotten 100xs more suspension stuff then we'll ever know.
Tell him your spring rates/sizes and how and where you want to drive and trust him to cover you.
I bought Koni Adjs for big red but never put them on since the Corvette Challenge/ Road America valving he did was PERFECT for Big Red.
Come to think of it, I just sold those Konis like last year and now I could use them in my new (to me) C4.
Well... guess I'm calling Jack too...
