oil pan - replace the pump too?
Old Apr 11, 2008 | 08:26 PM
dvette87's Avatar
dvette87
Default oil pan - replace the pump too?
I'm going to replace my rusted oil pan. My car runs good, the oil pressure is good, but it's 21 years old. Should I replace the pump while it's open?
Old Apr 11, 2008 | 09:15 PM
Pete K's Avatar
Pete K
Nope.
It spends it life completely submerged in oil. They almost never wear.
Disassemble, inspect, clean, and stuff it right back in.
Old Apr 11, 2008 | 09:16 PM
dvette87's Avatar
dvette87
Thanks Pete.
Old Apr 12, 2008 | 08:26 AM
Iroc57's Avatar
Iroc57
Originally Posted by Pete K
Nope.
It works fine so I wouldn't even do that.
Old Apr 12, 2008 | 10:36 AM
Kool88vette's Avatar
Kool88vette
Why change the pan because it's rusty? If it works don't fix it.
Old Apr 12, 2008 | 10:44 AM
dvette87's Avatar
dvette87
Oil pans are not thick metal. And my neighbor, a retired metal worker, tells me the process used to make them leaves them kind of weak. Rust, especially widespread rust like I have, further weakens the pan. I could leave it as is, but I'd rather not risk running down the highway and suddenly having oil pressure read 0.
If it were a little rusted, I probably wouldn't mess with it. It's totally fuzzy brown. No telling where it's weak, or how weak. And remember, rust never sleeps.
Old Apr 15, 2008 | 02:15 AM
DREGSZ's Avatar
DREGSZ
Conventional wisdom is to ALWAYS replace the pump and screen when replacing the pan.
I did once get a bad melling B pump but I swaped it out in an hour, (well maybe 3) with the motor in the car. (88' C4)
It does happen, but I still go with the rule
Old Apr 15, 2008 | 05:44 AM
pmihaltian's Avatar
pmihaltian
Slingshot
I had to replace my pan at about 80,000 miles due to cracks and stripped threads. When I replaced the pan, I installed a new high output oil pump while I was in there. I probably did not need to, but I felt that it was cheap insurance.
Old Apr 15, 2008 | 05:43 PM
DREGSZ's Avatar
DREGSZ
Since were having a thread sort of about it, I'll throw this out there.
Does anyone have a preference for regular volume pumps vs high volume pumps?
I thought the high volumes put more oil volume up into the heads to drain back down and therefore leave less in the pan which could lead to possible cavitation in hard turns.
If this is considered a highjack, then please ignore it.
Old Apr 15, 2008 | 07:16 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If you do replace the pump, spot weld the pick-up to the pump.
To oil pan - replace the pump too?
