Fuel injectors....clean or replace?
Old Apr 13, 2008 | 07:14 PM
fastrtnu's Avatar
fastrtnu
Default Fuel injectors....clean or replace?
My 87 is essentially stock. It has 126000 km (approximately 78000 miles) on it. The car has been in my family since it was brand new so I know its' exact maintenance history. Recently I have been having issues with it stalling when cold and also a popping noise when shifting. I've been told by people on here that my injectors are likely leaking and/or clogged.
What should I do? Take them out and attempt to clean them or just replace them alltogether? These are the original injectors that it left Bowling Green with.
What is involved in removing the injectors? If I do replace them, what do you recommend?
Thanks, save the wave!
Old Apr 13, 2008 | 08:16 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
we do both. However, for the money it pays to get newer technology injectors that work great in an L98. heres the link:
http://www.fuelinjectorconnection.co...&productId=134
Old Apr 13, 2008 | 08:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Typically I send a set of injectors to Rich at Cruzin Performance (link on my site) but, with >190k miles on my '88 injectors I decided to purchase a set of new units.
So I just picked up a set of 23lb/hr Accel injectors from Summit and will install them soon as I take care of the eternal "tax man"...
Old Apr 13, 2008 | 09:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
At 21 yrs old, Id just get new ones.
Old Apr 13, 2008 | 09:55 PM
fastrtnu's Avatar
fastrtnu
Thanks for all the help!
how difficult is it to install new ones?
Old Apr 13, 2008 | 10:00 PM
FICINJECTORS
Supporting Vendor
heres a thread of a customer that put them in yesterday.
http://forums.corvetteforum.com/show....php?t=1996124
Old Apr 13, 2008 | 11:47 PM
StealthLT4's Avatar
StealthLT4
I don't know about rates in your area, but it cost me $140 to have my injectors cleaned, serviced and flow-balanced. That's about half the price of brand new injectors right there, so I'd just go new if I were you.
Old Apr 14, 2008 | 05:53 AM
FICINJECTORS
Supporting Vendor
the 1987 corvette came stock with a 21.45lb Bosch injector made for Rochester Products with Pn 17111961. The trick flows sold by summit are 24lbs/ It is not recommended to put a 24lb injector in that car without ECU recalibration. Do not think you can just put a universal Injector in any engine. You always want to match the replacement size with the size injector that was engineered for your engine.
To Fuel injectors....clean or replace?
