Bad MAF Sensor?
Old Apr 14, 2008 | 08:37 PM
G-Sting's Avatar
G-Sting
Default Bad MAF Sensor?
How do you know if your MAF sensor is bad? My '96 LT1 has a Granatelli MAF which is no more than 4 years old. City Fuel economy is down to around 13 mpg, but highway still gets 25-28 mpg. No codes thrown. Recently replaced plugs, wires, EGR valve & solenoid, O2 sensors. A mechanic I had work to replace the FPR said the MAF sensor 'checked out bad'. Any thing I can do to verify this?
Thanks.
Old Apr 21, 2008 | 12:23 PM
G-Sting's Avatar
G-Sting
Well, I wasn't able to test the MAF, but talked to a friend who knows much about these things. He said if the mileage is low and the tailpipes looked more sooty than normal, replace the MAF. I replaced it with a new Granatelli 80mm MAF with cold air tuning from Jegs.
It purrs and runs like a champ, accelerates much better from a stop (no hesitation), and the mileage is way up.
Hope this helps someone else.
Old Apr 21, 2008 | 07:58 PM
SunCr's Avatar
SunCr
Glad it worked for you, but it's better to scan and see what fuel delivery looks like before purchasing parts.
Old Apr 21, 2008 | 09:24 PM
rickneworleansla's Avatar
rickneworleansla
This may be a stupid question but did you try cleaning it first? My stock MAF is still working at 100k miles. I clean it every 4 to 6 months.
Old Apr 22, 2008 | 10:47 AM
G-Sting's Avatar
G-Sting
Yes, for sure. I didn't have access to a scanner. It was a 'best guess' considering the inputs mentioned above.
Also, I have been cleaning the MAF with cleaner every 6 months or so.
To Bad MAF Sensor?
