86 rear alignment?
Old Apr 15, 2008 | 05:54 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default 86 rear alignment?
The left rear tire on my 86 roadster is tilted out slightly. I have inspected the rear undercarrage and all looks okay; nothing broken, bent or leaking. Is this just an alignment issue or might it be signs of other more serious problems?
Here is a photo of the left side (tilted out at bottom) and the right side (straight).
click photo to enlarge
Old Apr 15, 2008 | 06:50 AM
rich653's Avatar
rich653
If everything feels tight and bushings are in good shape then it is probably just a camber adjustment, the spec says 0.0 +/- 0.5. (stock settings) try putting a straight level vertical in the center of the tire from lower bead to upper bead so you can see the difference from side to side. When I checked mine the bubble is dead center on the right and just a touch off on the left. Are you seeing any abnormal wear on the tires? also make sure your on very level ground when eyeing the tires up make sure you drive it a few feet and then bounce the back a couple of times like checking shocks, if you had the car jacked up and haven't moved it then the suspension won't be in rest position.
Old Apr 15, 2008 | 02:03 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Good advice. Thanks much.
Old Apr 15, 2008 | 03:15 PM
jhammons01's Avatar
jhammons01
Did you jack it up and check for play in the actual bearing?
To 86 rear alignment?
