Another C5 Brakes on C4?
Can the C5 calipers be used in the back?
What about the C5 rear rotor? How did/do you incorporate the different style e-brake?
Can you use the C5 rear capiler on the C4 rotor?
Lots of questions. Hopefully someone can answer. I've been thinking about putting be Z06 calipers on because I really like their stock RED look. I don't think the front will be a problem, but I haven't heard anything about the rear.
You can mount a set of front calipers on the rear. The Electro-dynamics guys make an adapter to do this on early C4s but they haven't done the newer C4 yet. It might be the same as I don't think the rear brakes changed but I'm not sure. It is very expensive(add$400 on to the price of the front conversion to do the rear) and you get very little improvement in braking as the front does 80% of the work. I would paint the calipers for $10 and then they will match. Besides, the rear calipers on the C4 are just as good as C5 at braking but they have a better setup for the handbrake.
:cheers:
[Modified by 92TripleBlack, 10:11 PM 12/13/2001]
If you wish pictures can be posted at the Electro-Dynamics website or here later today. Let me know what you wish. As we use the C4 rear axle and bearings, there is approximately 1/8 inch less engagement of the shoe to the rotor drum. That is the major functional difference.
The installation of all C5 rear caliper, rotor, and parking brake is rather expensive due to all the machining.
The pictures are of the parts necessary for an early C4 rear, however the later C4 is similar, but with less aluminum material.
92tripblack is also correct in that Electro-Dynamics makes the adapters for C5 front caliper and rotors for the rear of the C4, both early (1984-87) and late (1988-96) late. This eliminates the parking brake, and is more visually stunning with the larger rotors and the large calipers with Corvette lettering.
They also make adapters for the fronts of the C4's, all years.
[Modified by R94 LT 1, 6:20 AM 12/15/2001]
Yes Electro-Dynamics has a functional C5 parking brake with the C5 rear caliper and rotor for a C4.
Electro-Dynamics made a committment to install the front C5 on the rear first. Most of the input was not to just duplicate the C5, but to make something better with standard components. Having done that, it was easier to adapt the C5 parking brake and the C5 rear caliper. The C5 front and rear calipers both take the same mount on the C5 Corvette itself.
The following is not how our current adapters are, but if had we utilzed the original C4 cast aluminum parking brake housing:
To make a different adapter for the cast aluminum piece on the C4's (early) would have smaller bolts (C4) taking the stress of an application that has larger bolts (14mm). Also the cast drum brake housing would have to be notched, as well as the caliper rotated. The adapter bracket would have been stepped. These things are not insurmountable, however we accomplished the same thing with a much cleaner look, by making a billet piece.
Thanks for inquiring (I'm logged on at work, if you don't recognize this post name)
Gene284
[Modified by FastC4, 4:04 PM 12/15/2001]
Yes, Electro-Dynamics offers the following:
BR-001 = C5/Z06 front caliper assembly and rotor mounted on the rear of C4, no parking brake. This looks awesome.
BR-002 = C5/Z06 rear caliper assembly and rotor mounted on the rear of C4, no parking brake
BR-003 = C5/Z06 rear caliper assembly, rotor and C5/Z06 parking brake mounted on the rear of C4. Yes, parking brake!
Go to http://www.electro-dynamics.com and press the "C5 and C54 Brakes" button. The information you may be seeking should be on the third page.
Feel free to email me should you have more questions.
[Modified by gene284, 3:45 PM 12/16/2001]
