Identifing the noise......
Old Apr 16, 2008 | 11:15 AM
welsh_gal's Avatar
welsh_gal
Default Identifing the noise......
Hi again guys
I've got a noise comming from the rear of the car. It like duh duh duh duh that gets quicker when you get faster. Its not a knocking or a scraping, somewhere in between. What are your thoughts? :o
Old Apr 16, 2008 | 12:03 PM
94flavette's Avatar
94flavette
Tires?
Old Apr 16, 2008 | 12:09 PM
lt4obsesses's Avatar
lt4obsesses
I say tires are the first place to look. Check your rear tires all the way around. I suspect you might find them to be a little more worn at one point than the rest of the tire. Had the same kind of noise, sure enough tires were flat spotted. New tires, no more noise.
Old Apr 16, 2008 | 12:20 PM
welsh_gal's Avatar
welsh_gal
The tires do need replacing, I'll change them and hopefully it should solve the problem.... It has a set of toyo proxes T1R on it atm. Any one heard of these? Any good recommendations of tires?
Old Apr 16, 2008 | 12:44 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If it's more like a "ticking" suspect the half-shaft U-joints; you can easily see such a problem after you pull the wheel and rotate the axle.
Old Apr 17, 2008 | 11:46 PM
DUBI's Avatar
DUBI
Default Ticking
I have the ticking noise problem on the drivers side . I replaced the u-joints on the 1/2 shaft---still ticking--Could it be the main Drive shaft u-joints????
Old Apr 18, 2008 | 01:48 AM
carguy604's Avatar
carguy604
I vote tires. I had the same prob on my Tahoe a few years back - turned out that a belt had shifted within the tire. New tires, no more duh, duh, duh!
Old Apr 18, 2008 | 01:55 AM
cv67's Avatar
cv67
St. Jude Donor '05
Stuttering boyfriend?
Old Apr 18, 2008 | 07:26 AM
Z51L9889's Avatar
Z51L9889
Sounds like tires to me.
OK, Ron ..... no soup for you!
Old Apr 18, 2008 | 08:09 AM
Red C4's Avatar
Red C4
I put Goodyear Eagle F1 tires on mine and I think they're great !
Old Apr 18, 2008 | 02:32 PM
welsh_gal's Avatar
welsh_gal
Ok had the wheels off today and couldn't see/hear any problems with the u-joints. Going to have to wait till payday to get a new set of tires, I'll let you know if it solves the prob. Time for tire research!
Old Apr 18, 2008 | 03:40 PM
Calderone's Avatar
Calderone
why don't you get together with another c4 owner,swap tires,go for a short ride and pay attention to the noise...then you'll know.-
If the noise went to the other car ....its TIRES ! .....tired tires !
Old Apr 18, 2008 | 08:35 PM
DUBI's Avatar
DUBI
Default clicking noise
I flipped the tires left front and right front---in reverse rotation as indicated and the clicking noise disappeared---The TIRE guys were right!! in this case anyway---Many Thanks!!!!
Old Apr 19, 2008 | 01:36 AM
welsh_gal's Avatar
welsh_gal
I would love to swap my tires with another c4 but...... I don't know anyone else with one
To Identifing the noise......
