pushrod selection
Old Apr 16, 2008 | 12:26 PM
87stocker's Avatar
87stocker
Default pushrod selection
Ok i need to know do i need to account for preload when checking pushrod length, if so what figure do i work with. I shimmed my hydrolic lifters with washers and checked like that. Is there another way i should do it. Please someone point me in the right direction. Also how do i know where my rockers should be sitting on my studs, I know my pushrod length will determine that but is there a too low or high spot.
Old Apr 16, 2008 | 12:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When valve train geometry is correct the rocker tip will roll back & forth along a path that's centered in the center of the valve tip.
So long as the rocker moves without friction it's position up/down on the stud is not important.
You can buy a pushrod of adjustable length for determining correct pushrod length.
Why are you concerned with this topic??
Old Apr 16, 2008 | 01:50 PM
87stocker's Avatar
87stocker
i just did trick flow heads a comp cams cam 1.6 rr a first intake and may othes and now i need to determine the push rod length so im wondering do i need to account for preload on the lifters. many people say to go with a solid lifter and or shim up the hydrolic one to determine the length. so what im asking is can someone give me exact no detail left out on how to determine proper push rod length. there is a pile of links ive found but none of them have stated what to do with the preload on hydrolic lifters. and my concern with the rocker arm is that it can be anywhere on the stud but how do you know if it is too high up on the stud with pushrods in place or too low .
Old Apr 16, 2008 | 01:54 PM
ultraviolet70's Avatar
ultraviolet70
Check out this thread w/links.
http://forums.corvetteforum.com/show....php?t=1682812
Old Apr 16, 2008 | 04:23 PM
65Z01's Avatar
65Z01
...my concern with the rocker arm is that it can be anywhere on the stud but how do you know if it is too high up on the stud with pushrods in place or too low .
There is no practical too high nor low for it, IMO.
The rocker will ride where it must to give the proper preload for the pushrod length chosen.
I'm thinking that, even with the adjustable pushrod, you set preload and then watch the rocker tip travel across the valve tip as you manually rotate the crankshaft. So the preload here would be the same as for the final valve lash adjustment.
Old Apr 16, 2008 | 08:17 PM
bowtieclassics's Avatar
bowtieclassics
Yes, watch the rocker travel across the top of the valve stem but there is a way to see the actual pattern. "paint" the end of the valve stem with a magic marker. Assembly the rocker arm and manually rotate the engine a few times. Remove the rocker arm and you will see a definite mark on top of the valve stem where the rocker contacts it. Of course this mark should be reasonably centered on the stem. Adjust the push rod to center the mark.
Old Apr 17, 2008 | 10:25 AM
87stocker's Avatar
87stocker
ok i got the whole part about how to measure for length. the ? i am asking is do i need to shim the lifter to make it a solid lifter or should i be doing this with a normal hydrolic roler lifter. i have heard both stories now and i want to get this right.
Old Apr 17, 2008 | 10:57 AM
CFI-EFI's Avatar
CFI-EFI
For the most accurate results, substitute in a solid lifter for the hydraulic lifer to keep the valve spring from depressing the plunger. Alternately, you can check for proper geometry with light, "checking springs" in the head. It is an easy matter to factor in the preload distance for push rod length, where necessary.
RACE ON!!!
To pushrod selection
