Engine Noise - Did I break it?
Over the winter, I installed a Hot Cam kit, 4.10 gears (with mechanics help), Adj. fuel pressure regulator, EM long tube headers, high flow cats, true dual 2 1/2" exhaust, MSD opti, hurst shifter, new water pump. All went pretty smoothly, including startup and initial break-in of the cam.
However, I am now getting a large noise that sounds appears to be coming from somewhere near the passenger side valve cover or underneath the intake manifold. Sounds like TICK, TICK, TICK, TICK, etc. I can easily hear the noise from inside the car. The noise is not apparent at idle, nor at 2000 rpm, but starts at about 3000 RPM. The noise started about 1/2way through my 1st test drive of about 5 miles.
Oil pressure is good. Fuel pressure is good. I have adjusted the valves several times using the methods outlined on this forum while car is running. No success in getting rid of the noise. I re-used the lifters and push rods, being careful to re-install them in their original locations. The push rods were straight. The lifters did not show any wear. Spark plugs are tight, no exhaust leaks. I will double check the firing order again tonight. Driver's side does not make this noise.
I used dino 10W30 to break-in the cam and am about to change back to the recommened Mobile 1 oil & new filter. Could this change in oil cause this type of noise somehow?
Car starts and runs fine. No codes. I removed the drip tabs from the valve covers. Rockers are not hitting the valve covers. Running the car with the valve cover removed does not reveal any apparent improper operation of the valves & springs.
Any ideas about what may be causing this noise or how to diagnose it? I really do not look forward to removing the intake again. Thanks in advance for your help!
I just thought of something, did you check the specs on the cam against the capabilities of the stock LT1 springs, or did the kit come with new springs? If you used the stock springs and they can't handle the lift of the new cam, that could be causing your problem and that would explain why it sounds fine at idle and up to 2000 rpms but after that starts making noise.
Thanks for your suggestion!
