I'm trying to find out which part I need, but I'm getting conflicting info from the FSM and the internet.
I need, I think..."Switch Assembly, Engine Oil Pressure Indicator" according to the FSM. When I tried to find the part online, it shows the same part as the "Sensor, Fuel Pump Switch, and Engine Oil Pressure Gage". It's the longer of the two that I need. What is the part called?
What are you looking for? What year do you have? Some years have the oil pressure switch and oil pressure sender as separate devices. Others have them combined into a single, three wire, unit. If yours is a year with them combined as one, it doesn't matter. If yours are separate, you need to know which you need. Are you working on the gauge or the fuel pump operation?
'93. I was looking to see what the exact name was because in one book it lists the name as such, and in book 2 of the FSM, it lists it as another name.
