Traditional method: unplug both hoses from throttle body and plug them together.
How about??? remove both hoses and plug their origins? The one that enters the TB from the front comes from a T in the upper radiator hose and the on that enters the pass side of the TB Ts off of another heater hose. Why not just plug the two Ts and completely remove the hoses?
Re: Question about Alternate Method of TB Bypass???? (qblue92)
As far as I remember.. you need the flow going through there... can't remember if it's because it will cause an air pocket or where the feed is coming from that it needs to have the flow through.
Re: Question about Alternate Method of TB Bypass???? (ZBRA)
I'm pretty sure that on a 94-96, both ends are 3/8's. All you have to do is disconnect the hose coming from your radiator and plug it into the line coming form the heads. No extra connector, the parts are on your car. I know it works for the 96, just did it. Took 5 minutes.
i thought about the same thing...i'd like to find a couple of valves to put on each hose on the TB that i could open and close when i needed to...
I tried this, don't bother wasting the money unless you get some really high quality T valves. The ones I got busted a sprayed coolant out everywhere within a week :(. I would just replace the hose with a new one and don't even both hooking anything up with it (keep from having something else break)
Re: Question about Alternate Method of TB Bypass???? (Scooby)
Hmmm. Thanks... I'll have to go look into this whenever it stops storming outside. Until then I will keep working on this ark.
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Plugging the line coming from the rear of the heads is not a good idea.
Because of the reverse cooling system on LT1/LT4 engines, the heads need to vent any steam created around the exhaust ports back to the radiator. Otherwise, air will accumulate causing the heads to overheat. Not good.
So a steel return line was added to the back of the heads which takes a detour thru the throttle body before getting back to the radiator. A common method to by-pass the throttle body is to simply remove the hose that goes from the drivers side front of the throttle body and reroute it to the steel line that runs from the back of the heads and ends at the front of the intake manifold passangers side.
With your method you are shutting off the flow. The steam tube running along the valve cover needs to connect to the tee coming off the radiator in order to complete the flow.
Re: Question about Alternate Method of TB Bypass???? (Ed Ut)
All you have to do is complete the connection. You do not need coolant running throught the TB. You have a hose that starts a point A then it goes the point B(the TB) and then on the point C the heater hose line. Well just get the correct size heater hose and connect point A directly to point C. I have an L98 car so my setup was a little different, but I used a Aeroquip fitting coming out of my intake into a 10AN 120 degree fitting and used blue aeroquip silicone hose to go straight to my heater line. It works great and looks very cool.
Waaaay back I had a 68 Toyota Land Cruiser. It had a rear seat heater and the hoses to it passed through the passenger compartment. In the summer it would heat up the interiior just from passing through. It came from the factory with a two petcock style shut offs so you could stop the flow in the summer. So I know that Toyaota made such a thing and it worked just fine.
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
If you use 95+ upper radiator hose you don't need the T any more and for the heater hose you can put a prestone flush adapter in or get the 95+ molded hose also. I jusrt did this while replacing my radiator :cheers:
Re: Question about Alternate Method of TB Bypass???? (69shark)
If you wanted to use bypass valves for summer and colder weather (not winter driving, god no!!), you can go to a pluming supply and get the ball valves they use in heating. I would think that would work if thay had the right size. Worth looking at!! :yesnod:
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
:yesnod: :yesnod:
I've got a 95 Mikey has a 94
it's different. If you get the hose from a 95 your all set.
I wouldn't bother with a vavle.
That's what I was going to due, but I ran mine disconnected all last winter.
If it runs fine in Michigan winters your all fine too!
[Modified by BrianCunningham, 10:15 PM 12/15/2001]
I took care of this on my 94 when I put in the 383. I replaced the hoses that were connected together with the T fitting with one hose from the waterpump to the heater core. I used a section of cast iron pipe to connect the two upper raditor hoses together. Saved the parts for the TB heating stuff.
The stuff from the back of the heads goes to an aluminum line that sends the air to the upper overflow tank and antifreeze to the top of the radiator.
I just went to ACE hardware and picked up a hose barb that can connect two hoses. I then went and spent $2 on a new length of hose. On the 92 anyway, you can't just disconnect the hoses and connect them around the throttle body, you don't have the slack. So I took my new piece of hose and replaced the piece that comes off the T on the upper radiator hose. I just trimmed my new hose so that it meets up with the passenger side one with the hose barb. It looks fine and you don't have to worry about re-routing anything. You could also put it back very quickly if you felt like you needed it because nothing on the car has actually been modified.
