What's the correct idle speeds for an '86 auto?? Engine now sucks more air since I installed an Airaid TBS w/ new gaskets, used carb cleaner to cleanup the TB & removed the MAF screens which now resulted in a higher idle speed at startup. I disconnected the battery to reset the ecm but idle is still running high @ 700-800). I need some help to restore idle to within normal specs.
Specs are 100 +/- rpms from Targeted in PARK/NEUTRAL; 50 +/- rpms from Targeted in Drive. Until you hook up a Scanner, you won't know anything - so do that and repost with at least the following info: Engine Temp, TPS, Actual RPM, Targeted RPM, IAC Counts, A/C signal, PARK/Neutral Switch signal.
