86 Pace car idle problem
Old Apr 18, 2008 | 09:42 PM
55bluevette's Avatar
55bluevette
Default 86 Pace car idle problem
My 86 pace car idles rough, and I can't find the problem. The car starts up and runs great, and idles about 600-700 RPM's most of the time. Occassionaly while stopped with the motor idling, the car will rev up to 900 and back to 600, and sometimes it dies on me. I have replaced the IAC, and it didn't help it. Does anyone have any suggestions?
Old Apr 19, 2008 | 12:32 AM
86PACER's Avatar
86PACER
What was done before it began? Did someone set the timing? Is the Service engine light on?
Old Apr 19, 2008 | 12:43 AM
55bluevette
Nothing was done. No service engine light.
Old Apr 19, 2008 | 12:56 AM
86PACER's Avatar
86PACER
Since you replaced the IAC, you now need to reset the base idle speed (assuming you haven't done it).
http://forums.corvetteforum.com/show....php?t=1968281
I like to start with the basic things like checking the timing and vacuum leaks from burn or broken hoses under the hood. That can cause a fluctuating idle. I'm assuming you already did that. I also start the engine in the dark and look for any arcing at the plug wires that I can't see in the day. What's interesting is that the Engine light is not coming on even after stalling. Honestly, I'd try pulling codes anyway and see if there are any stored. Even if the light came on for a split second and went out again, there will be a code stored if the battery has not been disconnected. If there are codes, you have a starting point. All you need is a paperclip.
http://corvettebuyers.com/c4vettes/ecm.htm
Old Apr 19, 2008 | 08:06 AM
schrade's Avatar
schrade
Vacuum leak.
Old May 7, 2008 | 10:25 PM
55bluevette
Default Erratic idle on 86 Pace Car
Well, I had the car in the shop for 3 weeks, again, and they couldn't find what's causing it. They experenced the same problem, but couldn't find the cause. They didn't even charge me for the work on it this time. The car runs great, except for the idling. Any other suggestions?
Old May 7, 2008 | 10:33 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default idleing
Does it run the same in open loop verses closed loop?
Old May 8, 2008 | 07:28 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
My '85 had idle demons as well.
Here's what I did, one of these fixed the problem:
1. Pulled the EGR and threw it in the garbage. It may not have been seating correctly and/or the hard line was slightly cracked.
2. Doublechecked all grounds. They may have worked loose following header install.
3. Wire harness on the DS firewall. The insulation shrinked over time exposing wires that may have been shorting out across each other based on engine vibration. I taped them off.
4. Cleaned MAF and re-crimped harness wires.
5. Replaced PCV. $10 and 1 possibility eliminated.
6. Verified .47v - 4.6v on my TPS.
Now I'm idling like a monster. 700-760 without surge or stall.
To 86 Pace car idle problem
